Gesture_recognition_tlt_deepstream jupyter notebook hangup
I am running the jupyter notebook for the tutorial:
“Using NVIDIA Pre-trained Models and Transfer Learning Toolkit 3.0 to Create Gesture-based Interactions with a Robot”
When I run the training:
!tlt detectnet_v2 train -e $SPECS_DIR/egohands_train_resnet18_kitti.txt
-r $USER_EXPERIMENT_DIR/experiment_dir_unpruned
-k $KEY
-n resnet18_detector
–gpus $NUM_GPUS
I get this resulting error
2021-03-07 19:31:09,202 [WARNING] tlt.components.docker_handler.docker_handler:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the “user”:“UID:GID” in the
DockerOptions portion of the ~/.tlt_mounts.json file. You can obtain your
users UID and GID by using the “id -u” and “id -g” commands on the
terminal.
Using TensorFlow backend.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
WARNING:tensorflow:From /home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:43: The name tf.train.SessionRunHook is deprecated. Please use tf.estimator.SessionRunHook instead.
WARNING:tensorflow:From /home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/checkpoint_saver_hook.py:25: The name tf.train.CheckpointSaverHook is deprecated. Please use tf.estimator.CheckpointSaverHook instead.
WARNING:tensorflow:From /home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py:67: The name tf.logging.set_verbosity is deprecated. Please use tf.compat.v1.logging.set_verbosity instead.
WARNING:tensorflow:From /home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py:67: The name tf.logging.INFO is deprecated. Please use tf.compat.v1.logging.INFO instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
2021-03-08 03:31:17,488 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2021-03-08 03:31:17,488 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2021-03-08 03:31:18,136 [INFO] main: Loading experiment spec at /workspace/tlt-experiments/egohands/specs/egohands_train_resnet18_kitti.txt.
2021-03-08 03:31:18,137 [INFO] iva.detectnet_v2.spec_handler.spec_loader: Merging specification from /workspace/tlt-experiments/egohands/specs/egohands_train_resnet18_kitti.txt
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py”, line 797, in
File “”, line 2, in main
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/utilities/timer.py”, line 46, in wrapped_fn
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py”, line 790, in main
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py”, line 691, in run_experiment
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py”, line 569, in train_gridbox
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py”, line 26, in build_cost_auto_weight_hook
ValueError: steps_per_epoch must be > 0
File “/usr/local/bin/detectnet_v2”, line 8, in
sys.exit(main())
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/entrypoint/detectnet_v2.py”, line 12, in main
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/entrypoint/entrypoint.py”, line 296, in launch_job
AssertionError: Process run failed.
2021-03-07 19:31:18,948 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
print(‘Model for each epoch:’)
Do you mean you follow below guide?
yes
here is the link to the github repo:
Please double check the tfrecords setting in the training spec. Refer to Custom dataset -- ValueError: steps_per_epoch must be > 0
I did not pay attention to the instructions when preparing the egohands dataset
prepare_egohands.py must be modified:
return ’ '.join([‘hand’,
‘0’,
‘0’,
‘0’,
‘{} {} {} {}’.format(*box),
‘0 0 0’,
‘0 0 0’,
‘0’,
‘0’])
The bottom ‘0’ must be removed.
Then it will make the 15 count that is KITTI
So, the issue is gone. Right?
Yes
I did a video tutorial that shows how to set up the Egohands dataset for the “gesture_recognition_tlt_deepstream”
from the webinar.
There is a portion in that video that explains what the issues could be if not done right.
yes
I posted a response in forum also
Joe Valdivia
