Get camera image from gym in headless mode
I’m attempting to obtain the camera image from a robot-mounted camera that I have imported into my project in USD format. When I run the program in normal mode, I am able to successfully retrieve the camera feed. However, when running in headless mode, I encounter the error message below.
It’s worth noting that this issue pertains to the Omni Isaac Gym environments, which are a new gym integrated into Isaac Sim. To provide context, I have placed my robot inside the cartpole example. @toni.sm do you have any idea what could be causing the issue? Or what could be a way around it.
The code in set_up_scene
    def set_up_scene(self, scene) -> None:
        self.get_cartpole()
        super().set_up_scene(scene)
        self._cartpoles = ArticulationView(prim_paths_expr="/World/envs/.*/Cartpole", name="cartpole_view", reset_xform_properties=False)
        self.camera = Camera(prim_path="/World/envs/env_0/Cartpole/test/chassi/camera", resolution=(100,100))
        self.camera.initialize()
        self.camera.add_motion_vectors_to_frame()
        scene.add(self._cartpoles)
        return
I feel this is the important part of the error, but all error is bellow to.
  File "/home/oscsa287/.local/share/ov/pkg/isaac_sim-2022.2.0/exts/omni.isaac.sensor/omni/isaac/sensor/scripts/camera.py", line 109, in __init__
    self._rgb_annotator.attach([self._render_product_path])
  File "/home/oscsa287/.local/share/ov/pkg/isaac_sim-2022.2.0/extscache/omni.replicator.core-1.6.4+104.1.lx64.r.cp37/omni/replicator/core/scripts/annotators.py", line 379, in attach
    self.template_name, 0, render_products, attributes=self._init_params
  File "/home/oscsa287/.local/share/ov/pkg/isaac_sim-2022.2.0/kit/extscore/omni.syntheticdata/omni/syntheticdata/scripts/SyntheticData.py", line 1385, in activate_node_template
    SyntheticData._add_rendervar(rp, rv, stage)
  File "/home/oscsa287/.local/share/ov/pkg/isaac_sim-2022.2.0/kit/extscore/omni.syntheticdata/omni/syntheticdata/scripts/SyntheticData.py", line 694, in _add_rendervar
    vp_iface = omni.kit.viewport_legacy.get_viewport_interface()
  File "/home/oscsa287/.local/share/ov/pkg/isaac_sim-2022.2.0/kit/extscore/omni.kit.window.viewport/omni/kit/viewport_legacy/scripts/viewport.py", line 16, in get_viewport_interface
    get_viewport_interface.viewport = acquire_viewport_interface()
RuntimeError: Failed to acquire interface: omni::kit::IViewport (pluginName: nullptr)
Error executing job with overrides: ['task=Cartpole', 'headless=True']
  File "scripts/rlgames_train.py", line 109, in parse_hydra_configs
    task = initialize_task(cfg_dict, env)
  File "/home/oscsa287/.local/share/ov/pkg/isaac_sim-2022.2.0/OmniIsaacGymEnvs/omniisaacgymenvs/utils/task_util.py", line 70, in initialize_task
    env.set_task(task=task, sim_params=sim_config.get_physics_params(), backend="torch", init_sim=init_sim)
  File "/home/oscsa287/.local/share/ov/pkg/isaac_sim-2022.2.0/OmniIsaacGymEnvs/omniisaacgymenvs/envs/vec_env_rlgames.py", line 51, in set_task
    super().set_task(task, backend, sim_params, init_sim)
  File "/home/oscsa287/.local/share/ov/pkg/isaac_sim-2022.2.0/exts/omni.isaac.gym/omni/isaac/gym/vec_env/vec_env_base.py", line 80, in set_task
    self._world.reset()
  File "/home/oscsa287/.local/share/ov/pkg/isaac_sim-2022.2.0/exts/omni.isaac.core/omni/isaac/core/world/world.py", line 275, in reset
    task.set_up_scene(self.scene)
  File "/home/oscsa287/.local/share/ov/pkg/isaac_sim-2022.2.0/OmniIsaacGymEnvs/omniisaacgymenvs/tasks/cartpole.py", line 85, in set_up_scene
Set the environment variable HYDRA_FULL_ERROR=1 for a complete stack trace.
Exception ignored in: <function _make_registry.<locals>._Registry.__del__ at 0x7ff6e54da050>
  File "/home/oscsa287/.local/share/ov/pkg/isaac_sim-2022.2.0/kit/extscore/omni.kit.viewport.registry/omni/kit/viewport/registry/registry.py", line 103, in __del__
  File "/home/oscsa287/.local/share/ov/pkg/isaac_sim-2022.2.0/kit/extscore/omni.kit.viewport.registry/omni/kit/viewport/registry/registry.py", line 98, in destroy
TypeError: 'NoneType' object is not callable
Exception ignored in: <function SettingChangeSubscription.__del__ at 0x7ff758c8d9e0>
  File "/home/oscsa287/.local/share/ov/pkg/isaac_sim-2022.2.0/kit/kernel/py/omni/kit/app/_impl/__init__.py", line 114, in __del__
AttributeError: 'NoneType' object has no attribute 'get_settings'
2023-03-10 19:25:44 [9,017ms] [Error] [omni.usd] TF_PYTHON_EXCEPTION: in TfPyConvertPythonExceptionToTfErrors at line 114 of /buildAgent/work/ca6c508eae419cf8/USD/pxr/base/tf/pyError.cpp -- Tf Python Exception
2023-03-10 19:25:44 [9,018ms] [Error] [omni.usd] TF_PYTHON_EXCEPTION: in TfPyConvertPythonExceptionToTfErrors at line 114 of /buildAgent/work/ca6c508eae419cf8/USD/pxr/base/tf/pyError.cpp -- Tf Python Exception
2023-03-10 19:25:45 [9,103ms] [Warning] [carb.audio.context] 1 contexts were leaked
Hi @fira
The SimulationApp instance, in headless, use a simplified experience configuration (apps/omni.isaac.sim.python.gym.headless.kit) that doesn’t include several viewport/rendering-related extensions.
Although I don’t get the same error as you, I had to perform the following steps to be able to launch a headless simulation with a camera (like your code snippet) and without errors
  • comment the lines 33-34 in exts/omni.isaac.gym/omni/isaac/gym/vec_env/vec_env_base.py to avoid loading omni.isaac.sim.python.gym.headless.kit experience in headless mode
        experience = ""
        # if headless:
        #     experience = f'{os.environ["EXP_PATH"]}/omni.isaac.sim.python.gym.headless.kit'
  • run the script with the following arguments:
     headless=True +task.sim.enable_viewport=True task.sim.enable_cameras=True
Note: Even with that, I am not sure everything with works. I think we need to wait for the integration of camera tensor API in futures releases to do massive parallel RL with visual information successfully
Thanks @toni.sm ! Yes, the headless app that the gym environments use does not currently support headless rendering. We will be modifying the logic for this slightly in the upcoming release and adding support for headless rendering by specifying the enable_cameras parameter in the task config.
