Hello everyone,
I was working on an OpenCL application using the Apple platform and I wanted to try to test it on the Windows OS. I booted up the Windows partition(Not VM) on my Macbook Pro and after porting the code over, I noticed that some of the kernels were not working correctly. It seems that the get_global_id function does not return the correct value when I passed “1” as the argument. I made a small sample program and recreated the error.
#include <iostream>
#include <..\cl.hpp>
#include <map>
#include <vector>
#include <iterator>
std::string source(
"__kernel void test( __global float* outVector,\
int size)\
outVector[get_local_id(1)*10+get_local_id(0)] = get_global_id(1);\
int main (int argc, const char * argv[])
std::vector<cl::Platform> platforms;
cl::Platform::get(&platforms);
std::vector<cl::Device> devices;
platforms[0].getDevices(CL_DEVICE_TYPE_ALL, &devices);
cl::Context context(devices);
cl::CommandQueue queue(context, devices[0]);
cl::Program::Sources sources(1, std::make_pair(source.c_str(), source.size()));
cl::Program program(context, sources);
std::string build_options("");
program.build(devices,build_options.c_str());
std::vector<cl::Kernel> program_kernels;
program.createKernels(&program_kernels);
std::map<std::string, cl::Kernel> kernels_found;
std::string kernel_name;
for ( int i = 0; i < program_kernels.size(); ++i )
kernel_name = program_kernels[i].getInfo<CL_KERNEL_FUNCTION_NAME>();
std::cout << "Kernel found: " << kernel_name << std::endl;
kernels_found[kernel_name] = program_kernels[i];
std::vector<float> values(100);
cl::Buffer out_vector(context,CL_MEM_USE_HOST_PTR | CL_MEM_READ_WRITE, sizeof(float) * 100, &values[0]);
cl::Kernel test= kernels_found["test"];
test.setArg(0, out_vector);
test.setArg(1, 100);
queue.enqueueNDRangeKernel(test,0,cl::NDRange(10,10), cl::NDRange(10,10));
queue.enqueueReadBuffer(out_vector,CL_TRUE, 0,sizeof(float)*100, &values[0]);
queue.finish();
std::vector<float>::iterator it;
std::ostream_iterator<float> out_it(std::cout, "\t");
for(it = values.begin(); it != values.end(); it += 10)
std::copy(it, it+10, out_it);
std::cout << std::endl;
return 0;
Output:
Kernel found: test
3.43597e+009 3.43597e+009 3.43597e+009 3.43597e+009 3.43597e+009 3.43597e+009 3.43597e+009 3.43597e+009 3.43597e+009 3.4359
7e+009
7e+009
7e+009
7e+009
7e+009
7e+009
7e+009
7e+009
7e+009
7e+009
Press any key to continue . . .
Extra Info:
Machine: Apple Macbook Pro
Operating System: Windows 7 Professional (BOOTCAMP Partition)
IDE: Visual Studio 2010 Professional
GPU: GeForce 9400M
CUDA Toolkit: 4.0 RC2 (April 2011)
Driver: Notebook Developer Drivers for WinVista and Win7 (270.28)
Platform Version: OpenCL 1.0 CUDA 4.0.1
The get_global_id(0) and get_local_id functions work as expected. It seems like a driver issue. I haven’t found anything on the internet about this problem. Does anyone know of a workaround which would not require me to manually calculating the global id from the local and group ids.
I also noticed that the build fails if the __constant qualifier is used in the parameters of a kernel declaration. This seems to go against the OpenCL specifications.
Thanks,
Umar Arshad
