getPluginCreator could not find plugin
Hi, i follow the example “sampleUffSSD” to create my plugin,
Step 1.
i convert the pb file to uff file base on the following command
python3 convert_to_uff.py --input-file myNet.pb -O output -p config.py
the content of config.py
import graphsurgeon as gs
import tensorflow as tf
trt_SpaceToDepth = gs.create_plugin_node(name='spaceToDepth', op="SpaceToDepth_TRT", blockSize=2)
namespace_plugin_map = {
        "net/SpaceToDepth": trt_SpaceToDepth
def preprocess(dynamic_graph):
    # Now create a new graph by collapsing namespaces
    dynamic_graph.collapse_namespaces(namespace_plugin_map)
and the result message is
UFF Version 0.5.5
=== Automatically deduced input nodes ===
[name: "image_placeholder"
op: "Placeholder"
attr {
  key: "dtype"
  value {
    type: DT_FLOAT
attr {
  key: "shape"
  value {
    shape {
      dim {
      dim {
      dim {
      dim {
Using output node output
Converting to UFF graph
Warning: No conversion function registered for layer: SpaceToDepth_TRT yet.
Converting spaceToDepth as custom op: SpaceToDepth_TRT
No. nodes: 167
UFF Output written to myNet.uff
Step 2.
i modify sampleUffSSD.cpp as below
#include <string>
#include <iostream>
#include <cassert>
#include "NvUffParser.h"
#include "NvInferPlugin.h"
#include <opencv2/imgproc.hpp>
#include <opencv2/highgui.hpp>
#include "common.h"
const char* INPUT_BLOB_NAME{"image_placeholder"};
const char* OUTPUT_BLOB_NAME{"output"};
constexpr int INPUT_C = 3;
constexpr int INPUT_H = 480;
constexpr int INPUT_W = 480;
static Logger gLogger;
std::vector<std::pair<int64_t, DataType>>
calculateBindingBufferSizes(const ICudaEngine& engine, int nbBindings, int batchSize)
    std::vector<std::pair<int64_t, DataType>> sizes;
    for (int i = 0; i < nbBindings; ++i)
        Dims dims = engine.getBindingDimensions(i);
        DataType dtype = engine.getBindingDataType(i);
        int64_t eltCount = samplesCommon::volume(dims) * batchSize;
        sizes.push_back(std::make_pair(eltCount, dtype));
    return sizes;
ICudaEngine* loadModelAndCreateEngine(const char* uffFile, int maxBatchSize,
                                      nvuffparser::IUffParser* parser, IHostMemory*& trtModelStream)
    // Create the builder
    IBuilder* builder = createInferBuilder(gLogger);
    // Parse the UFF model to populate the network, then set the outputs.
    INetworkDefinition* network = builder->createNetwork();
    std::cout << "Begin parsing model..." << std::endl;
    if (!parser->parse(uffFile, *network, nvinfer1::DataType::kFLOAT)) {
        gLogger.log(ILogger::Severity::kERROR, "Fail to parse");
        // RETURN_AND_LOG(nullptr, ERROR, "Fail to parse");
std::cout << "End parsing model..." << std::endl;
    // Build the engine.
    builder->setMaxBatchSize(maxBatchSize);
    // The _GB literal operator is defined in common/common.h
    builder->setMaxWorkspaceSize(1_GB); // We need about 1GB of scratch space for the plugin layer for batch size 5.
    builder->setHalf2Mode(false);
    // if (args.runInInt8)
    //     builder->setInt8Mode(true);
    //     builder->setInt8Calibrator(calibrator);
    std::cout << "Begin building engine..." << std::endl;
    ICudaEngine* engine = builder->buildCudaEngine(*network);
    if (!engine) {
        gLogger.log(ILogger::Severity::kERROR, "Unable to create engine");
        // RETURN_AND_LOG(nullptr, ERROR, "Unable to create engine");
    std::cout << "End building engine..." << std::endl;
    // We don't need the network any more, and we can destroy the parser.
    network->destroy();
    parser->destroy();
    // Serialize the engine, then close everything down.
    trtModelStream = engine->serialize();
    builder->destroy();
    nvuffparser::shutdownProtobufLibrary();
    return engine;
void doInference(nvinfer1::IExecutionContext& context, float* inputData, float* detectionOut, int batchSize)
    const ICudaEngine& engine = context.getEngine();
    int nbBindings = engine.getNbBindings();
    std::vector<void*> buffers(nbBindings);
    std::vector<std::pair<int64_t, nvinfer1::DataType>> buffersSizes = calculateBindingBufferSizes(engine, nbBindings, batchSize);
    for(int i=0; i < nbBindings; ++i) {
        auto bufferSizesOutput = buffersSizes[i];
        buffers[i] = samplesCommon::safeCudaMalloc(bufferSizesOutput.first * samplesCommon::getElementSize(bufferSizesOutput.second));
    // In order to bind the buffers, we need to know the names of the input and output tensors.
    // Not that indices are guaranted to be less than IEngine::getNbBindings()
    int inputIndex = engine.getBindingIndex(INPUT_BLOB_NAME),
        outputIndex = engine.getBindingIndex(OUTPUT_BLOB_NAME);
    cudaStream_t stream;
    CHECK(cudaStreamCreate(&stream));
    // DMA the input to the GPU,  execute the batch asynchronously, and DMA it back:
    CHECK(cudaMemcpyAsync(buffers[inputIndex], inputData, batchSize * INPUT_C * INPUT_H * INPUT_W * sizeof(float), cudaMemcpyHostToDevice, stream));
    auto t_start = std::chrono::high_resolution_clock::now();
    context.execute(batchSize, &buffers[0]);
    auto t_end = std::chrono::high_resolution_clock::now();
    float total = std::chrono::duration<float, std::milli>(t_end - t_start).count();
    std::cout << "Time taken for inference is " << total << " ms." << std::endl;
    CHECK(cudaMemcpyAsync(detectionOut, buffers[outputIndex], batchSize * 15*15*5*12 * sizeof(float), cudaMemcpyDeviceToHost, stream));
    cudaStreamSynchronize(stream);
    // Release the stream and the buffers
    cudaStreamDestroy(stream);
    CHECK(cudaFree(buffers[inputIndex]));
    CHECK(cudaFree(buffers[outputIndex]));
// Helper function for serializing plugin
template<typename T>
void writeToBuffer(char*& buffer, const T& val)
    *reinterpret_cast<T*>(buffer) = val;
    buffer += sizeof(T);
T readFromBuffer(const char*& buffer)
    T val = *reinterpret_cast<const T*>(buffer);
    return val;
class SpaceToDepthPlugin: public nvinfer1::IPluginV2
public:
    // Ctor
    SpaceToDepthPlugin(int block_size): mBlockSize(block_size)
    SpaceToDepthPlugin(const void* data, size_t length)
        // Deserialize in the same order as serialization
        const char *d = static_cast<const char *>(data);
        const char *a = d;
        mBlockSize = readFromBuffer<int>(d);
        assert(d == (a + length));
    // IPluginV2 public function
    const char* getPluginType() const override
        return "SpaceToDepth_TRT";
    const char* getPluginVersion() const override
        return "1";
    int getNbOutputs() const override
        return 1;
    Dims getOutputDimensions(int index, const Dims *inputs, int nbInputDims) override
        assert(nbInputDims == 1);
        assert(index == 0);
        assert(inputs[index].nbDims == 3);
        int in_depth = inputs[0].d[0];
        int in_height = inputs[0].d[1];
        int in_width = inputs[0].d[2];
        assert(in_height % mBlockSize == 0);
        assert(in_width % mBlockSize == 0);
int out_depth = in_depth * mBlockSize*mBlockSize;
        int out_height = in_height / mBlockSize;
        int out_width = in_width / mBlockSize;
        return DimsCHW(out_depth, out_height, out_width);
    void configureWithFormat(const Dims* inputDims, int nbInputs, const Dims* outputDims, int nbOutputs, DataType type, PluginFormat format, int maxBatchSize) override
        assert(nbOutputs == 1);
        assert(type == DataType::kFLOAT);
        assert(format == PluginFormat::kNCHW);
        size_t volume = 1;
        for(int i = 0; i < inputDims->nbDims; i++) {
            volume *= inputDims->d[i];
        mInputVolume = volume;
    bool supportsFormat(DataType type, PluginFormat format) const override
        if(type == DataType::kFLOAT && format == PluginFormat::kNCHW) {
            return true;
        else {
            return false;
    int initialize() override { return 0; }
    void terminate() override
        // if something was initialized in "initialize()"
        // it must be terminated here
    IPluginV2* clone() const override
        return new SpaceToDepthPlugin(mBlockSize);
size_t getWorkspaceSize(int maxBatchSize) const override { return 0; }
    int enqueue(int batchSize, const void *const *inputs, void **outputs, void *workspace, cudaStream_t stream) override
        CHECK(cudaMemcpyAsync(outputs[0], inputs[0], mInputVolume * batchSize * sizeof(float), cudaMemcpyDeviceToDevice, stream));
        return 0;
    size_t getSerializationSize() const override
        return sizeof(int);
    void serialize(void *buffer) const override
        char *d = static_cast<char *>(buffer);
        const char *a = d;
        writeToBuffer(d, mBlockSize);
        assert(d == a + getSerializationSize());
    void destroy() override
        delete this;
    void setPluginNamespace(const char *pluginNamespace) override
        mNamespace = pluginNamespace;
    const char* getPluginNamespace() const override
        return mNamespace.c_str();
private:
    int mBlockSize;
    DimsCHW mOutDim;
    size_t mInputVolume;
    std::string mNamespace;
// Space to depth plugin specific constants
namespace
    const char* SPACETODEPTH_PLUGIN_VERSION{"1"};
    const char* SPACETODEPTH_PLUGIN_NAME{"SpaceToDepth_TRT"};
} // namespace
class SpaceToDepthCreator: public IPluginCreator
public:
    SpaceToDepthCreator()
        // Describe SpaceToDepth's required PluginField arguments
        mPluginAttributes.emplace_back(PluginField("blockSize", nullptr, PluginFieldType::kINT32, 1));
        // Fill PluginFieldCollection with PluginField arguments metadata
        mFC.nbFields = mPluginAttributes.size();
        mFC.fields = mPluginAttributes.data();
    ~SpaceToDepthCreator() {}
    const char* getPluginName() const override { return SPACETODEPTH_PLUGIN_NAME; }
    const char* getPluginVersion() const override { return SPACETODEPTH_PLUGIN_VERSION; }
    const PluginFieldCollection* getFieldNames() override { return &mFC; }
    IPluginV2* createPlugin(const char* name, const PluginFieldCollection* fc) override
        int blockSize;
        const PluginField* fields = fc->fields;
        // Parse fields from PluginFieldCollection
        assert(fc->nbFields == 1); // only block_size
        for(int i = 0; i < fc->nbFields; ++i) {
            if(strcmp(fields[i].name, "blockSize") == 0) {
                assert(fields[i].type == PluginFieldType::kINT32);
                blockSize = *(static_cast<const int*>(fields[i].data));
        return new SpaceToDepthPlugin(blockSize);
    IPluginV2* deserializePlugin(const char* name, const void* serialData, size_t serialLength) override
        // This object will be deleted when the network is destroyed, which will
        // call SpaceToDepth::destroy()
        return new SpaceToDepthPlugin(serialData, serialLength);
    void setPluginNamespace(const char* pluginNamespace) override { mNamespace = pluginNamespace; }
    const char* getPluginNamespace() const override { return mNamespace.c_str(); }
private:
    static PluginFieldCollection mFC;
    static std::vector<PluginField> mPluginAttributes;
// Static class fields initialization
PluginFieldCollection SpaceToDepthCreator::mFC{};
std::vector<PluginField> SpaceToDepthCreator::mPluginAttributes;
REGISTER_TENSORRT_PLUGIN(SpaceToDepthCreator);
int main(int argc, char* argv[])
    initLibNvInferPlugins(&gLogger, "");
    std::string uff_path = "myNet.uff";
    std::string img_file = "test_1.png";
    int batchSize = 1;
    cv::Mat cv_img = cv::imread(img_file);
    cv::resize(cv_img, cv_img, cv::Size(INPUT_H, INPUT_W));
    int depth = cv_img.channels();
    vector<float> inputData(batchSize * INPUT_C * INPUT_H * INPUT_W);
    for(int y = 0; y < cv_img.rows; y++) {
        for(int x = 0; x < cv_img.cols; x++) {
            cv::Vec3b pixel = cv_img.at<cv::Vec3b>(y,x);
            inputData[y*cv_img.cols*depth + x*depth + 0] = static_cast<float>(pixel.val[0]) / 255.0;
            inputData[y*cv_img.cols*depth + x*depth + 1] = static_cast<float>(pixel.val[1]) / 255.0;
            inputData[y*cv_img.cols*depth + x*depth + 2] = static_cast<float>(pixel.val[2]) / 255.0;
auto parser = nvuffparser::createUffParser();
    parser->registerInput("image_placeholder", DimsCHW(3, 480,480), nvuffparser::UffInputOrder::kNCHW);
    parser->registerOutput("output");
    IHostMemory* trtModelStream{nullptr};
    ICudaEngine* tmpEngine = loadModelAndCreateEngine(uff_path.c_str(), batchSize, parser, trtModelStream);
    assert(tmpEngine != nullptr);
    assert(trtModelStream != nullptr);
    tmpEngine->destroy();
// Deserialize the engine.
    std::cout << "*** Desserializing ***\n";
    IRuntime* runtime = nvinfer1::createInferRuntime(gLogger);
    assert(runtime != nullptr);
    ICudaEngine* engine = runtime->deserializeCudaEngine(trtModelStream->data(), trtModelStream->size(), nullptr);
    assert(engine != nullptr);
    trtModelStream->destroy();
    IExecutionContext* context = engine->createExecutionContext();
    assert(context != nullptr);
    // Host memory for outputs
    int nBboxParams = 5;
    int nClass = 7;
    int nAnchor = 5;
    std::vector<float> detectionOut(batchSize * 15 * 15 * nAnchor * (nBboxParams+nClass));
    // Run inference
    doInference(*context, &inputData[0], &detectionOut[0], batchSize);
But i got the error message after run the program
ERROR: getPluginCreator could not find plugin SpaceToDepth_TRTspaceToDepth version 1 namespace spaceToDepth
ERROR: Cannot deserialize plugin SpaceToDepth_TRT
The code above is fixed and the plugin can be deserialized.
could anyone tell me how to fix it?
my mistake, the call of constructor function in plugin creator does not match to my custom plugin.
now my plugin can be deserialized.
i fix the code above and leave it as an example for reference.
Thanks for updating with us.
Could you provide a little more information on what you did to solve your issue ?
All my plugin modules are compiled in .so modules that are properly loaded in the TRT python API and the whole graph works.
However, using the C++ API and loading the .so modules at runtime I have the same error.
getPluginCreator could not find plugin TilePlugin_TRT version 1 namespace
Cannot deserialize plugin TilePlugin_TRT
This part of the docs is quite unclear to me:
“Note: If you have your own plugin library, you can include a similar entry point to register all plugins in the registry under a unique namespace. This ensures there are no plugin name collisions during build time across different plugin libraries.”
For my program, the reason is the parameters of constructor of plugin is not matched when it is called in deserializePlugin of IPluginCreator.
For example (you can check the code i list above )
The one of constructor of Plugin is
SpaceToDepthPlugin(const void* data, size_t length, std::string name)
In deserializePlugin function of IPluginCreator, the arguments are not matched to the parameters of constructor so it can’t be constructed(instantiated)
hope it helps
P.S. i agree it is lack of document and information and TensorRT is like block box that i don’t know how to debug it.
