• Hardware Platform (Jetson / GPU) t4
• DeepStream Version 7.0
• TensorRT Version deepstream 7.0 installation guide
• NVIDIA GPU Driver Version (valid for GPU only) 535
Hi
I want to get obj_lable and class_id of my secondary nvinfer which is classier but i can only get object detection metadata using add probe in nvdsosd refer to deepstream-test2
i even check unique-component-id but is always 1 which is my primary nvinfer !
For the sake of clarity when i change my secondary ncinfer to object detection i can olso see its meta data and unique-component-id which is 2.
Even When i want to get classifier meta list i get this error:
Pyds.Glist object has no attribute unique_component_id
The following patch uses test2 as an example to obtain the label output by nvinfer unique_component_id==3
diff --git a/apps/deepstream-test2/deepstream_test_2.py b/apps/deepstream-test2/deepstream_test_2.py
index f787a7f5..05639a39 100755
--- a/apps/deepstream-test2/deepstream_test_2.py
+++ b/apps/deepstream-test2/deepstream_test_2.py
@@ -74,6 +74,30 @@ def osd_sink_pad_buffer_probe(pad,info,u_data):
try:
# Casting l_obj.data to pyds.NvDsObjectMeta
obj_meta=pyds.NvDsObjectMeta.cast(l_obj.data)
+ l_classifier = obj_meta.classifier_meta_list
+ while l_classifier is not None:
+ try:
+ classifier_meta = pyds.NvDsClassifierMeta.cast(l_classifier.data)
+ # Casting l_classifier.data to pyds.NvDsClassifierMeta
+ if classifier_meta.unique_component_id == 3:
+ # Print the classifier label
+ l_label = classifier_meta.label_info_list
+ while l_label is not None:
+ try:
+ label_info = pyds.NvDsLabelInfo.cast(l_label.data)
+ print("label:---> ", label_info.result_label)
+ except StopIteration:
+ break
+ try:
+ l_label = l_label.next
+ break
+ break
+ try:
+ l_classifier = l_classifier.next
+ break
break
obj_counter[obj_meta.class_id] += 1
@@ -244,7 +268,8 @@ def main(args):
sink = Gst.ElementFactory.make("nv3dsink", "nv3d-sink")
else:
print("Creating EGLSink \n")
- sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
+ # sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
+ sink = Gst.ElementFactory.make("fakesink", "nvvideo-renderer")
if not sink:
sys.stderr.write(" Unable to create egl sink \n")
