I trained a custom CNN and wanted to deploy it on the TX2. It works perfectly on 3 different systems (not ARM based). However, with the same weight file, input and source code, it gives outputs that are larger than expected.
Initially, I thought it was a version issue, however, I built another version from source (v0.3.0 and v0.3.1) and both give unexpected output values. Also, toggling the GPU-CPU flag does not help. I built the same version also on another system (from source) and it works fine.
I have tried it with PyTorch v0.3.0 and v0.3.1, and it does not work. I thought it might be an architecture issue so I actually trained on the Jetson and then evaluated it there but still got similar results.
Could you run the verification sample in dusty-nv tutorial first?
If possible, please provide an example code to help us reproduce this issue.
Maybe we can reproduce it by comparing the results of an x86-machine and Jetson TX2?
So running the commands from “Verify PyTorch” section, I get reasonable outputs:
nvidia@tegra-ubuntu:~$ python
Python 2.7.12 (default, Dec 4 2017, 14:50:18)
[GCC 5.4.0 20160609] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import torch
>>> print(torch.__version__)
0.3.0b0+af3964a
>>> print('CUDA available: ' + str(torch.cuda.is_available()))
CUDA available: True
>>> a = torch.cuda.FloatTensor(2).zero_()
>>> print('Tensor a = ' + str(a))
Tensor a =
0
0
[torch.cuda.FloatTensor of size 2 (GPU 0)]
>>> b = torch.randn(2).cuda()
>>> print('Tensor b = ' + str(b))
Tensor b =
0.8007
2.0221
>>> c = a + b
File "<stdin>", line 1
c = a + b
IndentationError: unexpected indent
>>> c = a + b
>>> print('Tensor c = ' + str(c))
Tensor c =
0.8007
2.0221
I am guessing it happens during the inference. Where can I attach the weights file and the inference scripts? Would it be possible to send it via email? Or do you suggest a better way to share the code with you?
I figured out what the issue was. The input to PyTorch is somehow between 0-255 on the TX2 while on 2 other laptops it was between 0-1 even though I do not use any normalization explicitly in my code and the code that ran on the machines was the same. After performing a division by 255 on the TX2, it works as expected.
It seems like there is an issue with libraries but I am not sure what caused it in the first place.
