I have a problem with the latest linux mint 21.1 with cinnamon environment. The system after installation was fully updated. The problem is that when I want to install the nvidia driver from the driver manager, e.g. version 525 or lower, it writes that:
**Error while installing package: installed nvidia-dkms-525 package post-installation script subprocess returned error exit status 10**
The card is rtx 2060 oc. I have secureboot and tpm enabled as I need windows 11 for my work. Sudo apt -f install does not do the trick. I changed the kernel to 5.19 and the problem is the same.
I am attaching the log from:
make.log (41.9 KB)
/var/lib/dkms/nvidia/525.60.11/build/make.log
Generally on ubuntu 22.04 distros I have this problem. Once I install some fork ubuntu, or even ubuntu 22.10 original with gnome, there is no problem for nvidia.
I don’t know how to fix it, I’m new to linux.
