Good day.
My problem happens on every driver. I had to install gcc-12 to compile the driver because it wouldn’t compile. Not work to boot with a 5.15 kernel, but it did boot with 5.19. Even though the driver is installed, it does not work. The problem is with every distribution that is based on ubuntu 22.04 LTS.
I am currently using the nvidia-driver-520-open (open kernel) driver
When I use a proprietary driver, the system does not boot at all.
Previously, this bug was not there, they had to add some update to ubuntu which is buggy. It’s the same on a clean system.
Current Linux Mint 21 Cinnamon distro.
sudo nvidia-smi
Unable to determine the device handle for GPU 0000:01:00.0: Not Found
nvidia-bug-report.log.gz (134.0 KB)
