When I change the drivers from the GUI, I get this error:
pk-client-error-quark: Cannot download packages whilst offline (257)
When I install them from the terminal, I get the following error:
root@thebeast:/home/soporte# nvidia-smi
No devices were found
root@thebeast:/home/soporte# dmesg | grep -i nvidia
[ 3.855779] nvidia: loading out-of-tree module taints kernel.
[ 3.856051] nvidia: module license ‘NVIDIA’ taints kernel.
[ 3.868570] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 3.892601] nvidia-nvlink: Nvlink Core is being initialized, major device number 507
[ 3.892623] NVRM: This PCI I/O region assigned to your NVIDIA device is invalid:
[ 3.903596] NVRM: This PCI I/O region assigned to your NVIDIA device is invalid:
[ 3.905111] nvidia 0000:e1:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 3.920764] NVRM: Loading NVIDIA UNIX x86_64 Kernel Module 570.153.02 Tue May 13 16:34:43 UTC 2025
[ 3.936622] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 570.153.02 Tue May 13 16:21:23 UTC 2025
[ 3.942171] [drm] [nvidia-drm] [GPU ID 0x0000e100] Loading driver
[ 3.957285] NVRM: The NVIDIA GPU 0000:e1:00.0 (PCI ID: 10de:2c02)
[ 3.989611] NVRM: installed in this system requires use of the NVIDIA open kernel modules.
[ 3.989661] [drm:nv_drm_load [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x0000e100] Failed to allocate NvKmsKapiDevice
[ 3.989797] [drm:nv_drm_register_drm_device [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x0000e100] Failed to register device
[ 6.699987] nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
[ 7.524007] audit: type=1400 audit(1750204340.787:6): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“nvidia_modprobe” pid=1309 comm=“apparmor_parser”
[ 7.524009] audit: type=1400 audit(1750204340.787:7): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“nvidia_modprobe//kmod” pid=1309 comm=“apparmor_parser”
[ 20.927211] NVRM: The NVIDIA GPU 0000:e1:00.0 (PCI ID: 10de:2c02)
[ 20.935590] NVRM: installed in this system requires use of the NVIDIA open kernel modules.
[ 20.944473] NVRM: The NVIDIA GPU 0000:e1:00.0 (PCI ID: 10de:2c02)
[ 20.952526] NVRM: installed in this system requires use of the NVIDIA open kernel modules.
[ 21.236839] NVRM: The NVIDIA GPU 0000:e1:00.0 (PCI ID: 10de:2c02)
[ 21.245031] NVRM: installed in this system requires use of the NVIDIA open kernel modules.
[ 21.252862] NVRM: The NVIDIA GPU 0000:e1:00.0 (PCI ID: 10de:2c02)
[ 21.260944] NVRM: installed in this system requires use of the NVIDIA open kernel modules.
[ 30.698450] NVRM: The NVIDIA GPU 0000:e1:00.0 (PCI ID: 10de:2c02)
[ 30.698454] NVRM: installed in this system requires use of the NVIDIA open kernel modules.
I downloaded the recommended one:
nvidia-driver-570
I also downloaded this, but it didn’t work:
