2 GPUs only 1 detected on Ubuntu 22.04 with nvidia-driver-510
Driver version : 510
OS : Ubuntu 22.04
Kernel : 5.15.0-30-generic
1st GPU : GeForce GTX 1050 Mobile
2nd GPU : GeForce GTX 3060
nvidia-bug-report.log (2.4 MB)
Please check if it works with a 460 driver.
Is pci=realloc needed for this ?
No, resources are properly allocated
Subsystem: NVIDIA Corporation GA106 [GeForce RTX 3060]
Flags: bus master, fast devsel, latency 0, IRQ 18
Memory at da000000 (32-bit, non-prefetchable) [size=16M]
Memory at 80000000 (64-bit, prefetchable) [size=256M]
Memory at 90000000 (64-bit, prefetchable) [size=32M]
I/O ports at d000 [size=128]
I guess it’s the known driver bug only. A bios update might be worth a shot.
nvidia-bug-report (1).log.gz (461.8 KB)
Bug report with nvidia-driver-460
BIOS version is the latest available.
It’s running flawlessly on Windows though.
That’s driver 470.129. I guess you can’t install 460 from repo on ubuntu anymore, only from runfile (of course, you’ll have to remove the repo driver beforehand).
Can you tell where can I get the exact run file?
460.80 ?
460.80 couldn’t build on kernel 5.15.0-30-generic
Please check if this version works:
https://http.download.nvidia.com/XFree86/Linux-x86_64/470.74/
Driver archive:
Damn, that worked.
Just a final question, so I shouldn’t ever update nvidia drivers?
Sorry one more. WHat version of CUDA will work with this?
I guess it’s 11.4. Just run nvidia-smi, this will show the supported maximum cuda version of the driver.
Since it’s a driver bug that’s known for quite some time now, this should hopefully be fixed anytime soon with a driver update. So once a new driver update gets released, you should check if that fixes it. At least you now have a working driver version to revert to.
