Hi, I wanted to use glDebugMessageControl to get debug messages.
There are lots of notifications, which I do not need at the moment.
So I tried following (in Delphi), but still I get all the notifications.
if Assigned(glDebugMessageCallback) then begin
glEnable(GL_DEBUG_OUTPUT_SYNCHRONOUS);
glDebugMessageCallback(rglDebugProc, nil);
NepouzitaId:=0;
glDebugMessageControl(GL_DONT_CARE, GL_DONT_CARE, GL_DONT_CARE, 0, @NepouzitaId, GL_FALSE);
glDebugMessageControl(GL_DONT_CARE, GL_DONT_CARE, GL_DEBUG_SEVERITY_NOTIFICATION, 0, @NepouzitaId, GL_FALSE);
glDebugMessageControl(GL_DONT_CARE, GL_DONT_CARE, GL_DEBUG_SEVERITY_LOW, 0, @NepouzitaId, GL_FALSE);
glDebugMessageControl(GL_DONT_CARE, GL_DONT_CARE, GL_DEBUG_SEVERITY_MEDIUM, 0, @NepouzitaId, GL_FALSE);
glDebugMessageControl(GL_DONT_CARE, GL_DONT_CARE, GL_DEBUG_SEVERITY_HIGH, 0, @NepouzitaId, GL_TRUE);
end;
I still get:
Notification: Buffer detailed info: Trying to allocate VBO (1) with size:, 24 bytes to location: VID
Notification: Buffer detailed info: Buffer object 1 (bound to GL_ARRAY_BUFFER_ARB, usage hint is GL_STATIC_DRAW) will use VIDEO memory as the source for buffer object operations.
Notification: Buffer detailed info: Freeing VBO (1) with size:, 24 bytes from location: VID
Is there some other setting to disable notifications, or is it a bug in the driver? Nvidia GeForce GT 1030, Windows 10 64bit, driver 390.77.
Kind regards,
Karel
