I am currently developing a shader library which utilizes subroutines. Compiling the shaders works fine, although linking them outputs this error:
Internal error: assembly compile error for fragment shader at offset 7617:
-- error message --
line 203, column 13: error: CBUFFER variables may be used only in LDC instructions
line 204, column 13: error: CBUFFER variables may be used only in LDC instructions
line 205, column 13: error: CBUFFER variables may be used only in LDC instructions
line 206, column 13: error: CBUFFER variables may be used only in LDC instructions
I then get the internal assembly text:
-- internal assembly text --
!!NVfp5.0
OPTION NV_gpu_program_fp64;
OPTION NV_bindless_texture;
OPTION NV_shader_atomic_float;
OPTION ARB_draw_buffers;
# cgc version 3.4.0001, build date Jul 2 2014
# command line args:
#vendor NVIDIA Corporation
#version 3.4.0.1
#profile gp5fp
#program main
#semantic PerFrame : BUFFER[0]
#semantic ForwardLights : BUFFER[1]
#semantic JointPalette
#semantic JointInstanceTexture
#semantic ModelArray
#semantic LightShadowTexture
#semantic GlobalBackLightColor
#semantic GlobalLightColor
#semantic GlobalAmbientLightColor
#semantic GlobalLightDir
#semantic GlobalBackLightOffset
#semantic Model
#semantic InvModel
#semantic EmitterTransform
#semantic OcclusionConstants
#semantic RenderTargetDimensions
#semantic RepeatIndex
#semantic MatDiffuse
#semantic MatEmissiveIntensity
#semantic MatSpecularIntensity
#semantic AlphaSensitivity
#semantic AlphaBlendFactor
#semantic LightMapIntensity
#semantic FresnelPower
#semantic FresnelStrength
#semantic ObjectId
#semantic TessellationFactor
#semantic MaxDistance
#semantic MinDistance
#semantic HeightScale
#semantic SceneScale
#semantic AnimationDirection
#semantic AnimationAngle
#semantic Time
#semantic Random
#semantic AnimationLinearSpeed
#semantic AnimationAngularSpeed
#semantic NumXTiles
#semantic NumYTiles
#semantic WindWaveSize
#semantic WindSpeed
#semantic WindDirection
#semantic WindIntensity
#semantic WindForce
#semantic ViewMatrixArray
#semantic DiffuseMap
#semantic DisplacementMap
#semantic SpecularMap
#semantic EmissiveMap
#semantic NormalMap
#semantic RoughnessMap
#semantic EnvironmentMap
#semantic calcColor
#semantic calcBump
#semantic calcSpec
#semantic calcDepth
#semantic calcEnv
#var float4x4 View : BUFFER[0] : buffer[0][0], 4 : -1 : 0
#var float4x4 InvView : BUFFER[0] : buffer[0][64], 4 : -1 : 1
#var float4x4 ViewProjection : BUFFER[0] : buffer[0][128], 4 : -1 : 0
#var float4x4 Projection : BUFFER[0] : buffer[0][192], 4 : -1 : 0
#var float4x4 InvProjection : BUFFER[0] : buffer[0][256], 4 : -1 : 0
#var float4x4 InvViewProjection : BUFFER[0] : buffer[0][320], 4 : -1 : 0
#var float4 EyePos : BUFFER[0] : buffer[0][384] : -1 : 1
#var float4 FocalLength : BUFFER[0] : buffer[0][400] : -1 : 0
#var float4x4 LightProjTransformArray[0] : : buffer[1][0], 4 : -1 : 0
#var float4 LightPositionsArray[0] : : buffer[1][64] : -1 : 0
#var float4 LightColorArray[0] : : buffer[1][80] : -1 : 0
#var float4 LightProjMapOffsetArray[0] : : buffer[1][96] : -1 : 0
#var float4 LightShadowMapOffsetArray[0] : : buffer[1][112] : -1 : 0
#var float4 LightShadowSizeArray[0] : : buffer[1][128] : -1 : 0
#var int NumActiveLights : BUFFER[1] : buffer[1][144] : -1 : 0
#var float LightInvRangeArray[0] : : buffer[1][148] : -1 : 0
#var int LightTypeArray[0] : : buffer[1][152] : -1 : 0
#var bool LightCastsShadowsArray[0] : : buffer[1][156] : -1 : 0
#var float4x4 JointPalette[0] : : , 4 : -1 : 0
#var ulong JointInstanceTexture : : : -1 : 0
#var float4x4 ModelArray[0] : : , 4 : -1 : 0
#var ulong LightShadowTexture : : : -1 : 0
#var float4 GlobalBackLightColor : : : -1 : 0
#var float4 GlobalLightColor : : : -1 : 0
#var float4 GlobalAmbientLightColor : : : -1 : 0
#var float4 GlobalLightDir : : : -1 : 0
#var float GlobalBackLightOffset : : : -1 : 0
#var float4x4 Model : : , 4 : -1 : 0
#var float4x4 InvModel : : , 4 : -1 : 0
#var float4x4 EmitterTransform : : , 4 : -1 : 0
#var float4 OcclusionConstants : : : -1 : 0
#var float4 RenderTargetDimensions : : : -1 : 0
#var int RepeatIndex : : : -1 : 0
#var float4 MatDiffuse : : : -1 : 0
#var float MatEmissiveIntensity : : : -1 : 0
#var float MatSpecularIntensity : : c[0] : -1 : 1
#var float AlphaSensitivity : : : -1 : 0
#var float AlphaBlendFactor : : c[1] : -1 : 1
#var float LightMapIntensity : : : -1 : 0
#var float FresnelPower : : : -1 : 0
#var float FresnelStrength : : : -1 : 0
#var int ObjectId : : : -1 : 0
#var float TessellationFactor : : : -1 : 0
#var float MaxDistance : : : -1 : 0
#var float MinDistance : : : -1 : 0
#var float HeightScale : : : -1 : 0
#var float SceneScale : : : -1 : 0
#var float2 AnimationDirection : : : -1 : 0
#var float AnimationAngle : : : -1 : 0
#var float Time : : : -1 : 0
#var float Random : : : -1 : 0
#var float AnimationLinearSpeed : : : -1 : 0
#var float AnimationAngularSpeed : : : -1 : 0
#var int NumXTiles : : : -1 : 0
#var int NumYTiles : : : -1 : 0
#var float WindWaveSize : : : -1 : 0
#var float WindSpeed : : : -1 : 0
#var float4 WindDirection : : : -1 : 0
#var float WindIntensity : : : -1 : 0
#var float WindForce : : : -1 : 0
#var float4x4 ViewMatrixArray[0] : : , 4 : -1 : 0
#var ulong DiffuseMap : : c[2] : -1 : 1
#var ulong DisplacementMap : : : -1 : 0
#var ulong SpecularMap : : c[3] : -1 : 1
#var ulong EmissiveMap : : : -1 : 0
#var ulong NormalMap : : c[4] : -1 : 1
#var ulong RoughnessMap : : c[5] : -1 : 1
#var ulong EnvironmentMap : : c[6] : -1 : 1
#function 5 EnvironmentMapColor(4) () -> ()
#function 6 AlphaColorMultiply(5) () -> ()
#function 7 AlphaColor(6) () -> ()
#function 8 SimpleColorMultiply(7) () -> ()
#function 9 SimpleColor(8) () -> ()
#subroutine 0 calcColor CalculateColor
#function 1 FlatNormalFunctor(0) () -> ()
#function 2 NormalMapFunctor(1) () -> ()
#subroutine 1 calcBump CalculateBump
#function 10 ReflectiveSpecularFunctor(9) () -> ()
#function 11 NonReflectiveSpecularFunctor(10) () -> ()
#subroutine 2 calcSpec CalculateSpecular
#function 12 ViewSpaceDepthFunctor(11) () -> ()
#subroutine 3 calcDepth CalculateDepth
#function 3 NoEnvironment(2) () -> ()
#function 4 EnvironmentPBR(3) () -> ()
#subroutine 4 calcEnv CalculateEnvironment
#var float3 ViewSpacePos : $vin.ATTR0 : ATTR0 : -1 : 1
#var float3 Tangent : $vin.ATTR1 : ATTR1 : -1 : 1
#var float3 Normal : $vin.ATTR2 : ATTR2 : -1 : 1
#var float3 Binormal : $vin.ATTR3 : ATTR3 : -1 : 1
#var float2 UV : $vin.ATTR4 : ATTR4 : -1 : 1
#var float4 Albedo : $vout.COL0 : COL0[0] : -1 : 1
#var float4 Normals : $vout.COL1 : COL1[1] : -1 : 1
#var float Depth : $vout.COL2 : COL2[2] : -1 : 1
#var float4 Specular : $vout.COL3 : COL3[3] : -1 : 1
#var float4 Unshaded : $vout.COL4 : COL4[4] : -1 : 1
PARAM c[7] = { program.local[0..6] };
CBUFFER buf0[] = { program.buffer[0] };
CBUFFER buf1[] = { program.buffer[1] };
ATTRIB fragment_attrib[] = { fragment.attrib[0..4] };
TEMP R0, R1, R2, R3, R4, R5, R6, R7, R8, R9;
LONG TEMP D0, D1;
OUTPUT result_color0 = result.color;
OUTPUT result_color3 = result.color[3];
OUTPUT result_color4 = result.color[4];
OUTPUT result_color2 = result.color[2];
OUTPUT result_color1 = result.color[1];
SUBROUTINETYPE I0 { BB19, BB21, BB23, BB25, BB27 };
SUBROUTINE I0 program_subroutine_0 = program.subroutine[0];
SUBROUTINETYPE I1 { BB11, BB13 };
SUBROUTINE I1 program_subroutine_1 = program.subroutine[1];
SUBROUTINETYPE I2 { BB29, BB31 };
SUBROUTINE I2 program_subroutine_2 = program.subroutine[2];
SUBROUTINETYPE I3 { BB33 };
SUBROUTINE I3 program_subroutine_3 = program.subroutine[3];
SUBROUTINETYPE I4 { BB15, BB17 };
SUBROUTINE I4 program_subroutine_4 = program.subroutine[4];
PK64.U D0.x, c[2];
PK64.U D1.x, c[3];
TEX.F R0, fragment.attrib[4], handle(D0.x), 2D;
TEX.F R1.xyz, fragment.attrib[4], handle(D1.x), 2D;
PK64.U D1.x, c[4];
PK64.U D0.x, c[5];
MOV.F R2.xyz, fragment.attrib[1];
MOV.F R3.xyz, fragment.attrib[3];
MOV.F R4.xyz, fragment.attrib[2];
TEX.F R5.yw, fragment.attrib[4], handle(D1.x), 2D;
TEX.F R5.x, fragment.attrib[4], handle(D0.x), 2D;
CALI program_subroutine_1;
MOV.F R3.xyz, R1;
MOV.F R1.w, R5.x;
MOV.F R2.xyz, R4;
MOV.F R6.xyz, fragment.attrib[0];
LDC.F32X4 R7.xyz, buf0[384];
PK64.U D0.x, c[6];
MOV.F R8.x, buf0[64];
MOV.F R9.x, buf0[80];
MOV.F R8.w, buf0[96].x;
MOV.F R9.w, buf0[112].x;
CALI program_subroutine_4;
MOV.F R3, {1, 0, 0, 0}.x;
MOV.F R2.w, R5.x;
MOV.F R4.xyz, R6;
MOV.F R1.w, c[1].x;
CALI program_subroutine_0;
MOV.F result_color0, R0;
MOV.F R3.xyz, R1;
MOV.F R0.w, R5.x;
MOV.F R1.xyz, R4;
MOV.F R0.x, c[0];
CALI program_subroutine_2;
MOV.F result_color3, R0;
MOV.F result_color4, {0, 1, 0, 0}.xxxy;
MOV.F R0.xyz, fragment.attrib[0];
CALI program_subroutine_3;
DP3.F R0.x, R2, R2;
RSQ.F R0.x, R0.x;
MUL.F R1.xyz, R0.x, R2;
ADD.F R0.x, R1.z, {1, 0, 0, 0};
DIV.F R0.xy, R1, R0.x;
MAD.F R0.zw, R0.xyxy, {0.28126231, 0.5, 0, 0}.x, {0.28126231, 0.5, 0, 0}.y;
MAD.F R0.x, R0.w, {0.5, 0, 0, 0}, {0.5, 0, 0, 0};
MUL.F R0.y, R0.x, {255.99609, 0, 0, 0}.x;
MAD.F R0.x, R0.z, {0.5, 0, 0, 0}, {0.5, 0, 0, 0};
FLR.F R0.z, R0.y;
FRC.F result_color1.w, R0.y;
FLR.F R0.x, R0.y;
MUL.F result_color1.x, R0, {0.00390625, 0, 0, 0};
MUL.F result_color1.z, R0, {0.00390625, 0, 0, 0}.x;
FRC.F result_color1.y, R0;
MOV.F result_color2.x, R1.w;
RET (TR);
BB11 SUBROUTINENUM(0):
RET (TR);
BB13 SUBROUTINENUM(1):
MAD.F R5.zw, R5.xywy, {2, -1, 0, 0}.x, {2, -1, 0, 0}.y;
DP3.F R1.w, R3, R3;
RSQ.F R1.w, R1.w;
MUL.F R3.xyz, R1.w, R3;
DP3.F R1.w, R2, R2;
RSQ.F R1.w, R1.w;
MUL.F R2.xyz, R1.w, R2;
MUL.F R3.xyz, R5.w, R3;
DP3.F R1.w, R4, R4;
DP2.F R2.w, R5.zwzw, R5.zwzw;
ADD.F R2.w, -R2, {1, 0, 0, 0}.x;
RSQ.F R2.w, R2.w;
MAD.F R2.xyz, R5.z, R2, R3;
RSQ.F R1.w, R1.w;
RCP.F.SAT R2.w, R2.w;
MUL.F R3.xyz, R1.w, R4;
MAD.F R4.xyz, R2.w, R3, R2;
RET (TR);
BB15 SUBROUTINENUM(2):
MOV.F R6.xyz, {1, 0, 0, 0}.x;
RET (TR);
BB17 SUBROUTINENUM(3):
MUL.F R5.yzw, R9.xxyz, R6.y;
MAD.F R5.yzw, R8.xxyz, R6.x, R5;
MAD.F R5.yzw, R8.xwyz, R6.z, R5;
ADD.F R5.yzw, R5, R9.xwyz;
ADD.F R7.xyz, R7, -R5.yzww;
DP3.F R2.w, R7, R7;
RSQ.F R2.w, R2.w;
MUL.F R7.xyz, R2.w, R7;
MUL.F R9.xyz, R4.y, R9;
MAD.F R9.xyz, R4.x, R8, R9;
DP3.F R2.w, R6, R6;
MAD.F R8.xyz, R4.z, R8.wyzw, R9;
RSQ.F R2.w, R2.w;
MUL.F R6.xyz, R2.w, R6;
ADD.F R8.xyz, R8, {0, 0, 0, 0}.x;
DP3.F R2.w, R4, R6;
DP3.F R3.w, R8, -R7;
MUL.F R4.xyz, R8, R3.w;
ADD.F R3.w, -R2, {1, 0, 0, 0}.x;
MAD.F R6.xyz, -R4, {2, 0, 0, 0}.x, -R7;
MAD.F R2.w, -R1, {3, 4, 0, 0}.x, {3, 4, 0, 0}.y;
POW.F R3.w, R3.w, {5, 0, 0, 0}.x;
DIV.F R2.w, R3, R2.w;
MAD.F R4.xyz, -R3, R2.w, R2.w;
ADD.F.SAT R3.xyz, R3, R4;
MAD.F R6.w, -R1, {9, 0, 0, 0}.x, {9, 0, 0, 0}.x;
TXL.F R4.xyz, R6, handle(D0.x), CUBE;
MUL.F R6.xyz, R4, R3;
RET (TR);
BB19 SUBROUTINENUM(4):
MAD.F R3.xyz, R6, R2.w, -R2.w;
MAD.F R0.xyz, R3, R0, R0;
RET (TR);
BB21 SUBROUTINENUM(5):
MUL.F R0, R0, R3;
MUL.F R0, R0, R1.w;
RET (TR);
BB23 SUBROUTINENUM(6):
MUL.F R0, R0, R1.w;
RET (TR);
BB25 SUBROUTINENUM(7):
MUL.F R0, R0, R3;
RET (TR);
BB27 SUBROUTINENUM(8):
RET (TR);
BB29 SUBROUTINENUM(9):
MUL.F R0.xyz, R3, R0.x;
MUL.F R0.xyz, R0, R1;
RET (TR);
BB31 SUBROUTINENUM(10):
RET (TR);
BB33 SUBROUTINENUM(11):
DP3.F R0.x, R0, R0;
RSQ.F R0.x, R0.x;
RCP.F R1.w, R0.x;
RET (TR);
END
# 126 instructions, 10 R-regs, 2 D-regs
I have tested this on an ATI 7970 and it works fine.
My setup is W7 with a GTX 690 using the 340.52 driver.
