Glx graphics will not render in Linux user namespace (unshare -U). Normal X11 works fine. Glx graphics work fine in normal (shared) namespace.
#glxinfo // works fine
#unshare -U glxinfo // empty window frame but same framerate ?
Linux kernel 5.3.6.
glxinfo:
name of display: :0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: NVIDIA Corporation
server glx version string: 1.4
server glx extensions:
GLX_ARB_context_flush_control, GLX_ARB_create_context,
GLX_ARB_create_context_no_error, GLX_ARB_create_context_profile,
GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
GLX_ARB_multisample, GLX_EXT_buffer_age,
GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context, GLX_EXT_libglvnd,
GLX_EXT_stereo_tree, GLX_EXT_swap_control, GLX_EXT_swap_control_tear,
GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_NV_copy_buffer, GLX_NV_copy_image, GLX_NV_delay_before_swap,
GLX_NV_float_buffer, GLX_NV_multigpu_context,
GLX_NV_robustness_video_memory_purge, GLX_NV_swap_group,
GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGI_swap_control,
GLX_SGI_video_sync
nvidia-smi:
| NVIDIA-SMI 440.59 Driver Version: 440.59 CUDA Version: 10.2 |
| 0 Quadro P2000 Off | 00000000:04:00.0 Off | N/A |
| 46% 33C P8 4W / 75W | 33MiB / 5059MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 25483 G /usr/bin/Xorg 30MiB |
Anyone have any experience with this?
User namespaces are fairly new so not much info.
Scott
