Under regular user: glxgears
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 153 (GLX)
Minor opcode of failed request: 3 (X_GLXCreateContext)
Value in failed request: 0x0
Serial number of failed request: 29
Current serial number in output stream: 30
glxinfo
name of display: :0
Minor opcode of failed request: 24 (X_GLXCreateNewContext)
Serial number of failed request: 90
Current serial number in output stream: 91
Under root user: glxgears
Running synchronized to the vertical refresh. The framerate should be
approximately the same as the monitor refresh rate.
303 frames in 5.0 seconds = 60.449 FPS
301 frames in 5.0 seconds = 60.038 FPS
301 frames in 5.0 seconds = 60.042 FPS
Access rights are the most common reason. Then there might be weong libraries, using indirect GLX, etc.
Any difference in output when running
ldd /usr/bin/glxinfo
as user and root?
