Hi all,
Here is the setup
::Shared Workstation::
OS: Debian stable
GC: 2x Nvidia GTX 970
Driver: Nvidia 361.28
Then we have several machines connecting on this via ssh -X
From a debian testing machine running a Quadro K600 card and same nvidia drivers, here is the result of glewinfo
glewinfo
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 154 (GLX)
Minor opcode of failed request: 3 (X_GLXCreateContext)
Value in failed request: 0x0
Serial number of failed request: 24
Current serial number in output stream: 25
in my ldd listing I have
# ldd /usr/bin/glxinfo
linux-gate.so.1 (0xf7793000)
libGLEW.so.1.10 => /usr/lib/i386-linux-gnu/libGLEW.so.1.10 (0xf7709000)
libGLU.so.1 => /usr/lib/i386-linux-gnu/libGLU.so.1 (0xf7695000)
libGL.so.1 => /usr/lib/i386-linux-gnu/libGL.so.1 (0xf7585000)
libm.so.6 => /lib/i386-linux-gnu/i686/cmov/libm.so.6 (0xf753f000)
libX11.so.6 => /usr/lib/i386-linux-gnu/libX11.so.6 (0xf73ed000)
libXext.so.6 => /usr/lib/i386-linux-gnu/libXext.so.6 (0xf73d8000)
libc.so.6 => /lib/i386-linux-gnu/i686/cmov/libc.so.6 (0xf722b000)
libXmu.so.6 => /usr/lib/i386-linux-gnu/libXmu.so.6 (0xf7212000)
libXi.so.6 => /usr/lib/i386-linux-gnu/libXi.so.6 (0xf71ff000)
libstdc++.so.6 => /usr/lib/i386-linux-gnu/libstdc++.so.6 (0xf710d000)
libgcc_s.so.1 => /lib/i386-linux-gnu/libgcc_s.so.1 (0xf70f0000)
libnvidia-tls.so.361.28 => /usr/lib/i386-linux-gnu/tls/libnvidia-tls.so.361.28 (0xf70eb000)
libnvidia-glcore.so.361.28 => /usr/lib/i386-linux-gnu/libnvidia-glcore.so.361.28 (0xf4e65000)
libdl.so.2 => /lib/i386-linux-gnu/i686/cmov/libdl.so.2 (0xf4e60000)
/lib/ld-linux.so.2 (0xf7796000)
libxcb.so.1 => /usr/lib/i386-linux-gnu/libxcb.so.1 (0xf4e3a000)
libXt.so.6 => /usr/lib/i386-linux-gnu/libXt.so.6 (0xf4dd3000)
libXau.so.6 => /usr/lib/i386-linux-gnu/libXau.so.6 (0xf4dcf000)
libXdmcp.so.6 => /usr/lib/i386-linux-gnu/libXdmcp.so.6 (0xf4dc8000)
libSM.so.6 => /usr/lib/i386-linux-gnu/libSM.so.6 (0xf4dbe000)
libICE.so.6 => /usr/lib/i386-linux-gnu/libICE.so.6 (0xf4da1000)
libuuid.so.1 => /lib/i386-linux-gnu/libuuid.so.1 (0xf4d9b000)
and the libGL is pointing in the good place
# ls -l /usr/lib/i386-linux-gnu/libGL.so.1
lrwxrwxrwx 1 root root 15 Feb 15 13:11 /usr/lib/i386-linux-gnu/libGL.so.1 -> libGL.so.361.28
I tried different drivers, from nvidia website and from debian repository, on both machines, there is no way to run any opengl related stuffs.
Same if we try from another debian stable machine with more-less the same configuration !
Then from an old debian running an old Quadro and running 349.xx drivers everything is working fine, we can confirm it in the glewinfo output
GLEW version 1.10.0
Reporting capabilities of display localhost:12.0, visual 0x2b
Running on a Quadro 600/PCIe/SSE2 from NVIDIA Corporation
OpenGL version 2.1.2 NVIDIA 349.16 is supported
But when he runs “glxinfo” the Glx Rendering option if “off”
Anyway, is there something special to do to fix this issue ? I’m a bit lost with this stuff
Thanks in advance !
