Hi *,
I have a problem with libGL. I run glxgears on my terminal with NIVIDA Quadro FX 3800 and it works perfectly. The problem happens when I access a remote computer (no NVIDIA card) through ssh -X and then I run glxgears on the remote computer. I got the following message:
root@todd:[~]: LIBGL_DEBUG=verbose glxgears
libGL: screen 0 does not appear to be DRI2 capable
libGL: OpenDriver: trying /usr/lib64/dri/tls/swrast_dri.so
libGL: OpenDriver: trying /usr/lib64/dri/swrast_dri.so
libGL: Can't open configuration file /root/.drirc: No such file or directory.
libGL error: No matching fbConfigs or visuals found
libGL error: failed to load driver: swrast
Running synchronized to the vertical refresh. The framerate should be
approximately the same as the monitor refresh rate.
42410 frames in 13.5 seconds = 3144.570 FPS
786 frames in 12.4 seconds = 63.634 FPS
789 frames in 12.0 seconds = 65.650 FPS
So, the glxgears window pops up but the gears DO NOT rotate…
root@todd:[~]: LIBGL_DEBUG=verbose glxinfo | grep render
direct rendering: No (If you want to find out why, try setting LIBGL_DEBUG=verbose)
GLX_MESA_multithread_makecurrent, GLX_MESA_query_renderer,
OpenGL renderer string: Quadro FX 3800/PCIe/SSE2
I have tried this content in my xorg.conf:
Section "ServerFlags"
Option "AllowIndirectGLX" "on"
EndSection
Can you please help me to fix this problem?
Thank you,
Ema
