I’ve been looking for a solution for weeks.
I setup a machine with red hat 8.5. I am trying to run some cfd software.
Everything works fine when I run it locally.
When i try to run it through ssh it launches but will not use my nvidia card but only the intel one as seen on the graphics report :
Graphics Report
library: STAR Mesa OpenGL
LP_NUM_THREADS: 0
KNOB_MAX_WORKER_THREADS: 1
window: OSMesaOffscreenRenderWindow
OpenGL vendor string: Intel Corporation
OpenGL renderer string: SWR (LLVM 6.0, 256 bits)
OpenGL version string: 3.3 (Core Profile) Mesa 18.1.2
OpenGL shading language string: 3.30
While remote it seems to me that my x server keeps crashing. If i run glxgears i will get errors like this.
glxgears
X Error of failed request: BadAlloc (insufficient resources for operation)
Major opcode of failed request: 152 (GLX)
Minor opcode of failed request: 5 (X_GLXMakeCurrent)
Serial number of failed request: 0
Current serial number in output stream: 33
X connection to :1 broken (explicit kill or server shutdown)
Or sometimes it goes through with 50k FPS and dosen’t show the gears.
glxinfo always gives me this message :
X Error of failed request: GLXBadContextTag
Major opcode of failed request: 146 (GLX)
Serial number of failed request: 53
Current serial number in output stream: 53.
I don’t know where to start to solve this issue.
Here is my output of nvidia-smi
Tue Oct 4 14:09:50 2022
| NVIDIA-SMI 515.76 Driver Version: 515.76 CUDA Version: 11.7 |
| | | MIG M. |
| 0 NVIDIA RTX A4500 Off | 00000000:73:00.0 Off | Off |
| 30% 30C P8 8W / 200W | 29MiB / 20470MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 2769 G /usr/libexec/Xorg 10MiB |
| 0 N/A N/A 3116 G /usr/bin/gnome-shell 4MiB |
| 0 N/A N/A 3616 G …roxy-12.0.4.7508/etxproxy 3MiB |
| 0 N/A N/A 7397 G …roxy-12.0.4.7508/etxproxy 5MiB |
I have attached my bug-report log, my installer log and also some conf files I think maybe would be usefull.
Regards
