Our application requires opengl 4.6 and our server RHEL 8.3 having NVidia RTX6000 , but we unable render display with NVIDIA .
NVIDIA-SMI 510.39.01 Driver Version: 510.39.01 CUDA Version: 11.6
If you want to access the nvidia gpu over vnc, you’ll have to connect it to a real Xserver running on the nvidia gpu, e.g. using x11vnc. Running vncserver just creates a virtual xserver running on software rendering.
Dear Team,
we installled tight vnc in rhel 8.3 , please share any guide for connecting to X server in nvidia gpu
Please don’t print this e-mail unless you really need to. Disclaimer: The information in Indian Register Of Shipping’s email and any attachments is confidential and intended solely for the attention and use of the named addressee(s). This information may be subject to legal,professional or other privilege and further distribution of it is strictly prohibited without our authority. If you are not the intended recipient, you may not copy, distribute or disclose its content to any person or entity, use it for any purpose or store or copy the information in any medium. If you have received it in error, please notify the sender immediately and delete the message from your systems. Personal messages and/or opinions in a message are solely those of the author. IRS will accept no responsibility for such messages. You are advised to check the message for computer viruses using your own software before opening any attachments.
A rough outline would be
Dear Team,
Please clear on this query.
We Installed the Nvidia Quadro RTX6000 in the master Node HPC cluster and let me know whether the card is compatible for rendering In Physical Host or it rendering works only for Virtualization.
attached is the card which we installed.
While it’s mainly built to be used in vGPU setups, it can also be used for host graphics, it will then create a virtual monitor.
Dear Team
Please let us know any additional Software required for creating virtual Monitor or installing the driver will be enough.
We are Using RHEL8.3
root@~]# nvidia-smi
Fri Jan 28 15:02:10 2022
Installing the driver and creating an xorg.conf (so the Xserver doesn’t use the on-board graphics) should be sufficient.
Please find the xorg, but still facing issue with OPENGL application.
[r# cat xorg.conf
Section “ServerLayout”
Identifier “Layout0”
Screen 0 “Screen0” 0 0
InputDevice “Keyboard0” “CoreKeyboard”
InputDevice “Mouse0” “CorePointer”
EndSection
Section “Files”
EndSection
Section “InputDevice”
Identifier “Mouse0”
Driver “mouse”
Option “Protocol” “auto”
Option “Device” “/dev/input/mice”
Option “Emulate3Buttons” “no”
Option “ZAxisMapping” “4 5”
EndSection
Identifier “Keyboard0”
Driver “kbd”
EndSection
Section “Monitor”
Identifier “Monitor0”
VendorName “Unknown”
ModelName “Unknown”
Option “DPMS”
EndSection
Section “Device”
Identifier “Device0”
Driver “nvidia”
VendorName “NVIDIA Corporation”
BusID “PCI:47:0:0”
EndSection
Section “Screen”
Identifier “Screen0”
Device “Device0”
Monitor “Monitor0”
DefaultDepth 24
SubSection “Display”
Depth 24
EndSubSection
EndSection
And the configuration.
XXXX@xorg.conf.d]# cat nvidia.conf
Section “OutputClass”
Identifier “nvidia”
MatchDriver “nvidia-drm”
Driver “nvidia”
Option “PrimaryGPU” "yes
And the
[XXXX @xorg.conf.d]# cat nvidia.conf
Identifier “nvidia”
Driver “nvidia”
Option “PrimaryGPU” “yes”
EndSection
[root@navik xorg.conf.d]# cat 10-nvidia.conf
Identifier “nvidia”
Driver “nvidia”
Option “AllowEmptyInitialConfiguration”
Option “SLI” “Auto”
Option “BaseMosaic” “on”
EndSection
Identifier “intel”
MatchDriver “i915”
Driver “modesetting”
EndSection
Did you install, configure and run vnc0server?
Since I still have no idea what you’re trying to achieve, please check this howto:
https://thelinuxcluster.com/2010/07/25/using-turbovnc-0-6-and-virtualgl-2-1-4-to-run-opengl-application-remotely-on-centos/
