On a laptop with dedicated graphics card (below specs), whose name is ZB15G5
, I have ssh-ed (with -X) to a computer named abc
, in order to visualize some graphics…
ssh -X -Y username@abc...
After having ssh-ed, this is the error I receive when launching the application:
[david@ZB15G5 ~]$ ssh -X -Y username@abc...
[dcabu@thul ~]$ adfview
libGL error: No matching fbConfigs or visuals found
libGL error: failed to load driver: swrast
I have tried this ssh -X -Y
connection to abc
from a computer running linux as well, that hasn’t got a dedicated graphics card… and the application launches normally.
Specs for ZB15G5
[david@ZB15G5 ~]$ inxi -Fxxxz
System:
Host: ZB15G5 Kernel: 4.19.56-1-MANJARO x86_64 bits: 64 compiler: gcc
v: 9.1.0 Desktop: Gnome 3.32.2 wm: gnome-shell dm: GDM 3.32.0
Distro: Manjaro Linux
Machine:
Type: Laptop System: HP product: HP ZBook 15 G5 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: HP model: 842A v: KBC Version 15.37.00 serial: <filter> UEFI: HP
v: Q70 Ver. 01.07.00 date: 04/15/2019
Battery:
ID-1: BAT0 charge: 86.4 Wh condition: 88.8/88.8 Wh (100%) volts: 16.7/15.4
model: Hewlett-Packard Primary type: Li-ion serial: <filter>
status: Discharging
CPU:
Topology: 6-Core model: Intel Core i7-8750H bits: 64 type: MT MCP
arch: Kaby Lake rev: A L2 cache: 9216 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 53004
Speed: 1000 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 1000 2: 1000
3: 1001 4: 999 5: 1002 6: 1000 7: 1000 8: 1000 9: 1000 10: 1001 11: 1000
12: 1000
Graphics:
Device-1: NVIDIA GP107GLM [Quadro P1000 Mobile] vendor: Hewlett-Packard
driver: nvidia v: 430.26 bus ID: 01:00.0 chip ID: 10de:1cbb
Display: x11 server: X.org 1.20.5 driver: nvidia compositor: gnome-shell
resolution: <xdpyinfo missing>
OpenGL: renderer: Quadro P1000/PCIe/SSE2 v: 4.6.0 NVIDIA 430.26
direct render: Yes
Audio:
Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a348
Sound Server: ALSA v: k4.19.56-1-MANJARO
Network:
Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi
v: kernel bus ID: 00:14.3 chip ID: 8086:a370
IF: wlp0s20f3 state: up mac: <filter>
Device-2: Intel Ethernet I219-LM vendor: Hewlett-Packard driver: e1000e
v: 3.2.6-k port: efa0 bus ID: 00:1f.6 chip ID: 8086:15bb
IF: enp0s31f6 state: down mac: <filter>
Drives:
Local Storage: total: 476.94 GiB used: 43.03 GiB (9.0%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HAJQ-000H1
size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: EXA73H1Q
scheme: GPT
Partition:
ID-1: / size: 464.26 GiB used: 43.03 GiB (9.3%) fs: ext4
dev: /dev/nvme0n1p3
ID-2: swap-1 size: 4.00 GiB used: 0 KiB (0.0%) fs: swap
dev: /dev/nvme0n1p2
Sensors:
System Temperatures: cpu: 45.0 C mobo: 38.0 C gpu: nvidia temp: 39 C
Fan Speeds (RPM): N/A
Info:
Processes: 319 Uptime: N/A Memory: 31.27 GiB used: 1.56 GiB (5.0%)
Init: systemd v: 242 Compilers: gcc: 9.1.0 Shell: bash v: 5.0.7
running in: gnome-terminal inxi: 3.0.34
