I know nothing about this, but did a web search. It is sort of a longshot, but do you have package “gnome-shell-extensions”? See: dpkg -l | grep 'gnome.shell.extensions' sudo apt-get install gnome-shell-extensions
I do find it interesting that this occurs at the same time every day, so I am thinking this is either a cron job at that time, or else something on a timer in the Gnome environment itself.
This message has appeared immediately below the list of errors today
Jun 9 06:51:56 jetson-00-04-4b-e5-8e-a1 PackageKit: get-updates transaction /334_adddbcbc from uid 1000 finished with success after 891ms
I only have remote access to the unit at the moment are there are risks in running the commands you posted?
I don’t want to cause any problems and stop it from working as I cannot go to the unit for a while
No CRON Jons are listed in the syslog at this time, the one preceding these messages is 26 minutes earlier.
If the only thing done is to add package gnome.shell.extensions, then I would say there is “nearly” no risk. There is always some risk if you’ve not tested some particular install. Personally, if I were to run this command and it offers to install without changing other packages, then I would consider this “safe”. Still, I won’t say it is a guarantee.
If a lot of other packages must be installed or updated, then “safeness” goes down. It would just depend what those other packages are. An example of not safe would be if it were to update the Xorg server itself, or if it wanted to reconfigure something used in boot.
I don’t know about those IRQ warnings, but those would be related to hardware drivers (not a result of anything gnome.shell.extensions could be related to). I am wondering if this system has some sort of custom install, especially device tree or carrier board customizations?
I couldn’t tell you what is causing this. It might be a case of needing to remove applications one at a time (and putting them back) until the error message goes away.
