AGX Xavier reboots after 1 core cpu loads 100%
When I run cameras stream with argus_camera app or gst-launch-1.0 nvarguscamerasrc. After a few time the first core of CPU loads 100% and jetson reboots. When I stop displaying its work longer, but reboots.
I find same toopic but it didnt help me:
Previos topic: How much cameras AXG Xavier can processed? - #26 by kuskov.stanislav
Hardware: AGX Xavier, conecttech gmsl board JCB004, 2 leopard imx390 cameras
Software: Jetpack 4.4, CTI drivers for JCB004
nvpmodel -m 0
nvpmodel -d cool
sudo jetson_clocks
I’m try argus_camera --outputsize=640x480 and it works well more 5 hours
Thanks for confirm it. Please update it if can run more times.
Could you check the CPU usage is still 100% for 640x480 output size?
It works near 5 hours and CPU does not load 100%.
Also, I try to run some examples from /usr/src/nvidia/graphics_demos and it’s not load CPU and no reboots
Right now i want to try argus_camera --outputsize=640x480 with multiple session
argus_camera --outputsize=640x480 freezes too (multiple session).
I find same pretty same problem vithout solution here: Argus errors with high cpu load and subsequent issues - #24 by SanjayD
Logs same:
Jan 27 11:52:55 jetson nvargus-daemon[6225]: (Argus) Error InvalidState:  (propagating from src/api/ScfCaptureThread.cpp, function run(), line 109)
Jan 27 11:52:55 jetson nvargus-daemon[6225]: SCF: Error InvalidState: Session has suffered a critical failure (in src/api/Session.cpp, function capture(), line 667)
PS. I see what syslog file is large
I’m try to start my opencv gstreamer example and all works well vore 4 hours, but when i connect wifi usb adapter it freezes.
Syslog here: (before HDMI reconnection)
err.txt (230.5 KB)
I try to restart stream when usb wifi adapter was connected and Jetson reboots. Log here: after Jan 28 02:11:28 jetson kernel: [19699.847822] imx390 32-001c: imx390_set_gain: db: 84
syslog (558.8 KB)
It can be interesting too. Syslog before reboot. At now Errors in nvargus_daemon. Here I’m turn off time synchronization (do-timestamp=false)
err_nvargus.txt (97.9 KB)
log when i started argus_camera --outputsize=640x480
syslog (539.3 KB)
@ShaneCCC Any ideas?
Could you try below command before run the camera.
sudo systemctl stop nvphs.service
sudo systemctl list-units --type=service
UNIT                               LOAD   ACTIVE SUB     DESCRIPTION
accounts-daemon.service            loaded active running Accounts Service
alsa-restore.service               loaded active exited  Save/Restore Sound Card State
apport.service                     loaded active exited  LSB: automatic crash report generation
avahi-daemon.service               loaded active running Avahi mDNS/DNS-SD Stack
bluetooth.service                  loaded active running Bluetooth service
bolt.service                       loaded active running Thunderbolt system service
colord.service                     loaded active running Manage, Install and Generate Color Profiles
console-setup.service              loaded active exited  Set console font and keymap
containerd.service                 loaded active running containerd container runtime
cron.service                       loaded active running Regular background program processing daemon
dbus.service                       loaded active running D-Bus System Message Bus
fwupd.service                      loaded active running Firmware update daemon
gdm.service                        loaded active running GNOME Display Manager
grub-common.service                loaded active exited  LSB: Record successful boot for GRUB
haveged.service                    loaded active running Entropy daemon using the HAVEGE algorithm
kerneloops.service                 loaded active running Tool to automatically collect and submit kernel crash signatures
keyboard-setup.service             loaded active exited  Set the console keyboard layout
kmod-static-nodes.service          loaded active exited  Create list of required static device nodes for the current kernel
ModemManager.service               loaded active running Modem Manager
networkd-dispatcher.service        loaded active running Dispatcher daemon for systemd-networkd
networking.service                 loaded active exited  Raise network interfaces
NetworkManager.service             loaded active running Network Manager
nv-l4t-usb-device-mode.service     loaded active exited  Configure USB flashing port for device mode
nvargus-daemon.service             loaded active running Argus daemon
nvgetty.service                    loaded active running UART on ttyTHS0
nvs-service.service                loaded active running NVS-SERVICE Embedded Sensor HAL Daemon
packagekit.service                 loaded active running PackageKit Daemon
polkit.service                     loaded active running Authorization Manager
resolvconf.service                 loaded active exited  Nameserver information manager
rpcbind.service                    loaded active running RPC bind portmap service
rsyslog.service                    loaded active running System Logging Service
rtkit-daemon.service               loaded active running RealtimeKit Scheduling Policy Service
serial-getty@ttyGS0.service        loaded active running Serial Getty on ttyGS0
serial-getty@ttyTCU0.service       loaded active running Serial Getty on ttyTCU0
setvtrgb.service                   loaded active exited  Set console scheme
snapd.seeded.service               loaded active exited  Wait until snapd is fully seeded
speech-dispatcher.service          loaded active exited  LSB: Speech Dispatcher
ssh.service                        loaded active running OpenBSD Secure Shell server
sysstat.service                    loaded active exited  Resets System Activity Data Collector
systemd-journal-flush.service      loaded active exited  Flush Journal to Persistent Storage
systemd-journald.service           loaded active running Journal Service
systemd-logind.service             loaded active running Login Service
systemd-modules-load.service       loaded active exited  Load Kernel Modules
systemd-random-seed.service        loaded active exited  Load/Save Random Seed
systemd-remount-fs.service         loaded active exited  Remount Root and Kernel File Systems
systemd-resolved.service           loaded active running Network Name Resolution
systemd-sysctl.service             loaded active exited  Apply Kernel Variables
systemd-timesyncd.service          loaded active running Network Time Synchronization
systemd-tmpfiles-setup-dev.service loaded active exited  Create Static Device Nodes in /dev
systemd-tmpfiles-setup.service     loaded active exited  Create Volatile Files and Directories
systemd-udev-trigger.service       loaded active exited  udev Coldplug all Devices
systemd-udevd.service              loaded active running udev Kernel Device Manager
systemd-update-utmp.service        loaded active exited  Update UTMP about System Boot/Shutdown
systemd-user-sessions.service      loaded active exited  Permit User Sessions
ubuntu-fan.service                 loaded active exited  Ubuntu FAN network setup
udisks2.service                    loaded active running Disk Manager
upower.service                     loaded active running Daemon for power management
user@1000.service                  loaded active running User Manager for UID 1000
whoopsie.service                   loaded active running crash report submission daemon
wpa_supplicant.service             loaded active running WPA supplicant
LOAD   = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB    = The low-level unit activation state, values depend on unit type.
60 loaded units listed. Pass --all to see loaded but inactive units, too.
To show all installed unit files use 'systemctl list-unit-files'.
@ShaneCCC
I find problem in bluetooth hostwake (cpu irq). How to turn off it forever?
I try disable bluetooth.service but it not help
I try this:
sudo modprobe -r bluedroid_pm
but it works before reboot
@WayneWWW
Do you have idea to disable buletooth interrupt for debug.
Or any experience for bluetooth cause CPU loading?
You can directly remove bluedroid_pm.ko file from /lib/modules.
So, I’m add install bluedroid_pm /bin/false into /etc/modprobe.d/blacklist.conf.
It can stop this module and dependencies. Works well.
Thank You for Your help @ShaneCCC @WayneWWW !
BTW, could you check if jetpack4.5 also has this issue on your board? This should be resolved on jp4.5.
I can not because camera drivers with conecttech gmsl board available for JP 4.3 and 4.4 only
I add a repo with a description of all fixes for the camera work.
Hope it helps other developers
