Got an error when run chatrtx app in windows 10
Environment path found: C:\Users\jayme\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag
App running with config
“models”: {
“supported”: [
“name”: “Mistral 7B int4”,
“installed”: true,
“metadata”: {
“model_path”: “model\mistral\mistral7b_int4_engine”,
“engine”: “llama_float16_tp1_rank0.engine”,
“tokenizer_path”: “model\mistral\mistral7b_hf”,
“max_new_tokens”: 1024,
“max_input_token”: 7168,
“temperature”: 0.1
“name”: “Llama 2 13B int4”,
“installed”: true,
“metadata”: {
“model_path”: “model\llama\llama13_int4_engine”,
“tokenizer_path”: “model\llama\llama13_hf”,
“max_input_token”: 3900,
“temperature”: 0.1
“selected”: “Mistral 7B int4”
“sample_questions”: [
“query”: “How does NVIDIA ACE generate emotional responses?”
“query”: “What is Portal prelude RTX?”
“query”: “What is important about Half Life 2 RTX?”
“query”: “When is the launch date for Ratchet & Clank: Rift Apart on PC?”
“dataset”: {
“sources”: [
“directory”,
“youtube”,
“nodataset”
“selected”: “directory”,
“path”: “dataset”,
“isRelative”: true
“strings”: {
“directory”: “Folder Path”,
“youtube”: “YouTube URL”,
“nodataset”: “AI model default”
File “C:\Users\jayme\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\langchain\embeddings\huggingface.py”, line 58, in init
import sentence_transformers
ModuleNotFoundError: No module named ‘sentence_transformers’
The above exception was the direct cause of the following exception:
File “C:\Users\jayme\AppData\Local\NVIDIA\ChatWithRTX\RAG\trt-llm-rag-windows-main\app.py”, line 114, in
embed_model = HuggingFaceEmbeddings(model_name=embedded_model)
File “C:\Users\jayme\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\langchain\embeddings\huggingface.py”, line 61, in init
raise ImportError(
ImportError: Could not import sentence_transformers python package. Please install it with pip install sentence-transformers.
Press any key to continue . . .
when run chatrtx on windows 10 got this error sow how to resolve of an issue
System-specification:
Platform-windows 10
nvidia driver version - 560
cuda version - 12.5
For support options please see this: SUPPORT for ChatRTX Users
