I wanna control the six cameras using J106 carrier board.And I followed the steps in the wiki http://developer.ridgerun.com/wiki/index.php?title=Getting_started_guide_for_Auvidea_J106_board
the frist step:
GPIO = 148
DIRECTION = out
VALUE = 1
sudo su
echo $GPIO > /sys/class/gpio/export
echo DIRECTION > /sys/class/gpio/gpio$GPIO/direction
echo VALUE > /sys/class/gpio/gpio$GPIO/value
But when I run echo 148 > /sys/class/gpio/export, I got the error :echo:write error: Invalid argument.
Does anyone konw what’s the matter? I wonder if the GPIO number is 148 on TX2,because the wiki is for TX1.
Regards.
hello BradleyY,
please refer to below code to know the GPIO numbers for TX2,
r28.1_sources/kernel/t18x/drivers/pinctrl/pinctrl-tegra186.c
Hi JerryChang
Thanks for your reply. Do you know the path of the file which describes the GPIO numbers for TX1?
here you are, r28.1_sources/kernel/kernel-4.4/drivers/pinctrl/pinctrl-tegra210.c
I find in TX1 pinctrl file the GPIO148 is defind:
#define TEGRA_PIN_CAM_RST_PS4 _GPIO(148)
In TX2 pinctrl file:
#define TEGRA_PIN_VCOMP_ALERT_PS4 _GPIO(148)
I didn’t find the defination which contained the key word CAM_RST in TX2 pinctrl file.So I wonder if there is no need to do the step 1 in the wiki http://developer.ridgerun.com/wiki/index.php?title=Getting_started_guide_for_Auvidea_J106_board So I go to the next step:run the command
sudo i2cdetect -y -r 0
I get:
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: UU UU -- -- -- -- -- -- 48 -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- —
As the wiki says ,I should detected the address 0x64 or 0x12,because I use the raspberry pi camera v2.1.
So I wonder if there is no need to do the configuration for TX2 GPIO.If the configuration is needed ,which pin should I run echo command ?
Or is there some configurations I havn’t done for using the camera on J106 board on TX2?
