Hi @DaneLLL,
I ran some shell commands on Jetson hacks
//Header pin 15 , Module pin name GPIO12, Module pin #218, tegra pin name, LCD_TE, default setting GPIO, gpio port PY.02
//GPIO 194 corresponds to header pin 15
$ echo 194 > /sys/class/gpio/export
$ echo out > /sys/class/gpio/gpio194/direction
$ echo 1 > /sys/class/gpio/gpio194/value
$ echo 0 > /sys/class/gpio/gpio194/value
The pin seems to work, I’m able to light an LED using an npn transistor. However the pin isn’t outputting 3.3V, about 3V ish, and and there is a 5MHz noise on the line. That’s something electrical I’ll have to figure out later. Also, I was expecting 3.3V, but maybe the Jetson puts out another voltage from the pin?
My code doesn’t cause the LED to light, so in that domain, I have a feeling its my code that I’m not setting a register or something. I’m not sure what register I’m forgetting to set. The following is an excerpt of the registers I’m using.
myPinMuxController.setRegisterField(PINMUX_AUX_LCD_TE_0::addressOffset, 0, PINMUX_AUX_LCD_TE_0::PM_bit, PINMUX_AUX_LCD_TE_0::PM_bitWidth);
myPinMuxController.setRegisterField(PINMUX_AUX_LCD_TE_0::addressOffset, 0, PINMUX_AUX_LCD_TE_0::PUPD_bit, PINMUX_AUX_LCD_TE_0::PUPD_bitWidth);
myPinMuxController.setRegisterField(PINMUX_AUX_LCD_TE_0::addressOffset, 0, PINMUX_AUX_LCD_TE_0::TRISTATE_bit, PINMUX_AUX_LCD_TE_0::TRISTATE_bitWidth);
myPinMuxController.setRegisterField(PINMUX_AUX_LCD_TE_0::addressOffset, 0, PINMUX_AUX_LCD_TE_0::PARK_bit, PINMUX_AUX_LCD_TE_0::PARK_bitWidth);
myPinMuxController.setRegisterField(PINMUX_AUX_LCD_TE_0::addressOffset, 0, PINMUX_AUX_LCD_TE_0::E_INPUT_bit, PINMUX_AUX_LCD_TE_0::E_INPUT_bitWidth);
uint32_t readPM = myPinMuxController.getRegisterField(PINMUX_AUX_LCD_TE_0::addressOffset, PINMUX_AUX_LCD_TE_0::PM_bit, PINMUX_AUX_LCD_TE_0::PM_bitWidth);
uint32_t readPUPD = myPinMuxController.getRegisterField(PINMUX_AUX_LCD_TE_0::addressOffset, PINMUX_AUX_LCD_TE_0::PUPD_bit, PINMUX_AUX_LCD_TE_0::PUPD_bitWidth);
uint32_t readTRI = myPinMuxController.getRegisterField(PINMUX_AUX_LCD_TE_0::addressOffset, PINMUX_AUX_LCD_TE_0::TRISTATE_bit, PINMUX_AUX_LCD_TE_0::TRISTATE_bitWidth);
uint32_t readPARK = myPinMuxController.getRegisterField(PINMUX_AUX_LCD_TE_0::addressOffset, PINMUX_AUX_LCD_TE_0::PARK_bit, PINMUX_AUX_LCD_TE_0::PARK_bitWidth);
uint32_t readINPUT = myPinMuxController.getRegisterField(PINMUX_AUX_LCD_TE_0::addressOffset, PINMUX_AUX_LCD_TE_0::E_INPUT_bit, PINMUX_AUX_LCD_TE_0::E_INPUT_bitWidth);
std::cout<<"pinmux PM bit: "<<readPM<<std::endl;
std::cout<<"pinmux PUPD bit: "<<readPUPD<<std::endl;
std::cout<<"pinmux TRISTATE bit: "<<readTRI<<std::endl;
std::cout<<"pinmux PARK bit: "<<readPARK<<std::endl;
std::cout<<"pinmux INPUT bit: "<<readINPUT<<std::endl;
// port Y is the zeroth port gpio controller 4 grouping
myGpioController.setRegisterField(GPIO_CNF_0_RMW::addressOffset, gpioController::LOCK_BIT_DISABLE, GPIO_CNF_0_RMW::LOCK_2_baseBit, GPIO_CNF_0_RMW::LOCK_2_bitWidth);
myGpioController.setRegisterField(GPIO_CNF_0_RMW::addressOffset, gpioController::BIT_N_GPIO, GPIO_CNF_0_RMW::BIT_2_baseBit, GPIO_CNF_0_RMW::BIT_2_bitWidth);
myGpioController.setRegisterField(GPIO_OE_0_RMW::addressOffset, gpioController::BIT_N_DRIVEN, GPIO_OE_0_RMW::BIT_2_baseBit, GPIO_OE_0_RMW::BIT_2_bitWidth);
myGpioController.setRegisterField(GPIO_INT_ENB_0::addressOffset, gpioController::BIT_N_DISABLE, GPIO_INT_ENB_0::BIT_2_baseBit, GPIO_INT_ENB_0::BIT_2_bitWidth);
myGpioController.setRegisterField(GPIO_OUT_0_RMW::addressOffset, gpioPinState, GPIO_OUT_0_RMW::BIT_2_baseBit, GPIO_OUT_0_RMW::BIT_2_bitWidth);
