https://devtalk.nvidia.com/default/topic/1009932/jetson-tx1/gpio-interrupts/?offset=11#5245753
I follow the above link on external interrupt.
I try to use “GPIO8_ALS_PROX_INT” (on developer kit J21, pin 37) as an external interrupt. I followed the Derekmolloy tutorial which is a great tutorial and helps a lot.
Now I want to synchronize the time of interrupt in the user space, i.e. to notify application (C/C++ code) when external interrupt happens and being handled in the kernel space. I don’t want to use poll method, better interrupt. How can I generate an interrupt from kernel space to user space?
I have another concern is writing of kobject, because of more restriction of new kernel, writing of kobject seems not possible, any solution for this situation?
I also would like to add the module into kernel in application (C/C++ code) without doing it manually as “$sudo insmod button.ko”, any clue to do this?
