can I enable a GPIO pin on the 40 pin expansion header to be an interrupt line without modifying the pinmux table? Is there any library I can use for interrupt handling in c?
hello aplb,
there’s developer guide, Configuring the 40-Pin Expansion Header you may refer to by using Jetson-IO.
thanks
Thank you. However, there are still a couple parts that are unclear:
1.) It seems like I don’t need to enable interrupts, as the pins are already pre enabled as an interrupt in the original image?
2.)Is there a C library to implement interrupts in user space?
hello aplb,
here’s forum discussion thread for your reference, gpio interrupts from user space.
you may also access L4T sources packages from download center for reference,
please refer to below source, by checking cd_gpio for an example to process an interrupt from a GPIO.
thanks
$L4T_Sources/r32.5/Linux_for_Tegra/source/public/kernel/kernel-4.9/drivers/mmc/host/sdhci-tegra.c
Thanks Jerry,
So if I understand correctly. We enable the interrupt through the device tree file. The interrupt handler is in kernel space but we can actually communicate with the handler through user space?
hello aplb,
that’s correct,
please also refer to pinmux spreadsheets for the default board configurations.
you may have customization if you’re doing with SFIO/GPIO,
thanks
Hi Jerry,
Thank you. A couple things that I am confused about:
hello aplb,
please check cd_gpio in the sdhci-tegra.c kernel driver to process an interrupt from a GPIO.
for example, there’s definition in device tree.
sdhci_sd: sdhci@3400000 {
mmc-ocr-mask = <0x0>;
cd-inverted;
cd-gpios = <&tegra_main_gpio TEGRA194_MAIN_GPIO(G, 7) 0>;
nvidia,cd-wakeup-capable;
mmc-ocr-mask = <0>;
cd-inverted;
vmmc-supply = <&p3668_vdd_sdmmc1_sw>;
status = "okay";
there’s NX’s default pinmux configuration shows as below, it’s SFIO.
pinmux.0x02431020 = 0x00000400; # aud_mclk_ps4: aud, tristate-disable, input-disable, lpdr-disable
you may configure pinmux spreadsheets to make it as GPIO pin as below,
gpio_default: default {
gpio-input = <
TEGRA_GPIO(S, 4)
after that,
please refer to Jetson Xavier NX and Jetson AGX Xavier Series MB1 Platform Configuration, you should able to control GPIO09 after the board configuration update,
thanks
I think you are talking about a few different steps here.
hello aplb,
I don’t have an example to use an interrupt on the AUD_MCLK pin.
you may refer to sdhci-tegra.c kernel driver to process an interrupt from a GPIO.
according to NX’s default pinmux configuration, AUD_MCLK is configured as SFIO. you should have pinmux customization to change it as GPIO, and flashing the board to update the board configuration file.
since you’re working with Jetson NX Dev Kit, check device tree sources under Jakku folder.
for example,
$L4T_Sources/r32.5/Linux_for_Tegra/source/public/hardware/nvidia/platform/t19x/jakku/
