I’m using a 3x512x512 input tensor for a convolution layer.
When the kernel is 7x7 it runs at ~2.5ms and nvprof shows this:
GPU activities: 100.00% 26.878ms 10 2.6878ms 2.5754ms 2.9829ms void fused::fusedConvolutionReluKernel<fused::SrcChwcPtr_FltTex_Reader<float, int=1, int=1, int=1>, fused::KpqkPtrWriter<float, int=1, int=1>, float, float, int=3, int=4, int=1, int=7, int=7, int=1, int=1>(fused::ConvolutionParams<floatSrcType, int=1, int=1Type>)
When the kernel is 5x5 it runs at ~1.2ms and nvprof show this:
GPU activities: 100.00% 11.011ms 10 1.1011ms 1.0990ms 1.1058ms trt_volta_scudnn_128x32_relu_small_nn_v1
How do I know which implementation runs on the CUDA cores and which on Tensor cores?
Why the different implementation paths? Does it matter or scudnn means it runs on the CUDA cores(slower on Xavier) and the fusedConvolutionReluKernel on Tensor cores?
I understand that 5x5 should run faster - I’m mostly baffled as to how to know I’m using the Tensor cores and not the slower CUDA cores.
thanks
Eyal
