OK so quick details-
My rig-
MoBo: Gigabyte B550 ds3h motherboard
CPU: AMD® Ryzen 5 5600g
GPU: NVIDIA Corporation TU106 [GeForce RTX 2070]
OS: pop_OS 22.04 (LTS)
Graphics Driver: 515.48.07
BIOS: F15a
Now the problems-
Ok so like a week ago I went to distrohop to Fedora and learned that my BIOS had completely disappeared, systemctl reboot --firmware-setup didn’t even initiate a reboot because it couldn’t find the BIOS. After jumping through some hoops with every possible alternative, I eventually cleared the CMOS and like magic my BIOS was back and I was able to install Fedora.
Upon my initial boot into BIOS I noticed some settings had changed and options pertaining to my GPU were all gone. Oh well, I’ll install Fedora and figure it out later. On first boot with Fedora I noticed the fans on my GPU all turned off as soon as the initial Disk Encryption screen loaded. Weird as it was, I wasn’t too concerned, however after installing all of the NVIDIA software, I tried manually activating the GPU fans through nvidia-settings, only to see "Failed to set new Fan Speed! in the bottom left corner of the configuration window. In hopes that this was just a case of Fedora not playing nicely with NVIDIA, back to Pop I reverted.
I went through every set of graphics drivers, and the only time my fans stayed on was after purging all NVIDIA drivers, however that made 3d editing worthless. Launching nvidia-settings from the CLI, I get this: `~$ nvidia-settings
(nvidia-settings:8104): GLib-GObject-CRITICAL **: 12:33:38.312: g_object_unref: assertion ‘G_IS_OBJECT (object)’ failed
** (nvidia-settings:8104): WARNING **: 12:33:38.431: PRIME: Failed to execute child process “/usr/bin/prime-supported” (No such file or directory)
** Message: 12:33:38.431: PRIME: is it supported? no
and booting up I get:
[ 2.752819] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCIO.GP17.V
GA.LCD._BCM.AFN7], AE_NOT_FOUND (20210730/PSARGS-330)
[ 2.753977] ACPI Error: Aborting method \_SB.PCIO.GP17.VGA.LCD._BCM due to previous error (AE_NOT_FOUND) (20210730/psparse=529)
I run lspci -k and get
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne Root Complex
Subsystem: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne IOMMU
Subsystem: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge
Kernel driver in use: pcieport
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 51)
Subsystem: Gigabyte Technology Co., Ltd FCH SMBus Controller
Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
Subsystem: Gigabyte Technology Co., Ltd FCH LPC Bridge
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 3
Kernel driver in use: k10temp
Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 7
01:00.0 VGA compatible controller: NVIDIA Corporation TU106 [GeForce RTX 2070] (rev a1)
Subsystem: Micro-Star International Co., Ltd. [MSI] TU106 [GeForce RTX 2070]
Kernel driver in use: nvidia
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
01:00.1 Audio device: NVIDIA Corporation TU106 High Definition Audio Controller (rev a1)
Subsystem: Micro-Star International Co., Ltd. [MSI] TU106 High Definition Audio Controller
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
01:00.2 USB controller: NVIDIA Corporation TU106 USB 3.1 Host Controller (rev a1)
Subsystem: Micro-Star International Co., Ltd. [MSI] TU106 USB 3.1 Host Controller
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
01:00.3 Serial bus controller: NVIDIA Corporation TU106 USB Type-C UCSI Controller (rev a1)
Subsystem: Micro-Star International Co., Ltd. [MSI] TU106 USB Type-C UCSI Controller
Kernel modules: i2c_nvidia_gpu
02:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] Device 43ee
Subsystem: ASMedia Technology Inc. Device 1142
02:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] Device 43eb
Subsystem: ASMedia Technology Inc. Device 1062
Kernel driver in use: ahci
Kernel modules: ahci
02:00.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43e9
03:09.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43ea
04:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 16)
Subsystem: Gigabyte Technology Co., Ltd Onboard Ethernet
Kernel driver in use: r8169
Kernel modules: r8169
05:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Zeppelin/Raven/Raven2 PCIe Dummy Function (rev c9)
Subsystem: Gigabyte Technology Co., Ltd Zeppelin/Raven/Raven2 PCIe Dummy Function
05:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Renoir Radeon High Definition Audio Controller
Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Renoir Radeon High Definition Audio Controller
05:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
Subsystem: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
Kernel driver in use: ccp
Kernel modules: ccp
05:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
Subsystem: Gigabyte Technology Co., Ltd Renoir/Cezanne USB 3.1
05:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
05:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) HD Audio Controller
DeviceName: Realtek ALC1220
Subsystem: Gigabyte Technology Co., Ltd Family 17h (Models 10h-1fh) HD Audio Controller
