Hi
I am relatively new to cuda and I can get my code to compile and run, but it does not appear to be executing the module on the GPU. I have an example here taken from “CUDA Fortran for scientists and engineers”, and it is not executing on the GPU:
module simpleOps_m
contains
attributes(global) subroutine increment(a, b)
implicit none
integer , intent(inout) :: a(:)
integer , value :: b
integer :: i
i = threadIdx%x
a(i) = a(i)+b
end subroutine increment
end module simpleOps_m
program incrementTestGPU
use cudafor
use simpleOps_m
implicit none
integer , parameter :: n = 256
integer :: a(n), b
integer , device :: a_d(n)
a=1
b=3
a_d = a
call increment <<<1,n>>>(a_d , b)
a = a_d
write(*,*) "a = ", a
if (any(a /= 4)) then
write(*,*) "**** Program Failed ****"
else
write(*,*) "Program Passed"
endif
end program incrementTestGPU
I place the code in a file named test2.f95 and run the compiler command “pgf90 -Mcuda test2.f95”. However, when I run the program all the values of a are still 1 and I get program failed. I appears the part on the GPU is not running. I am using PGI community edition on ubuntu 16.04.
Any idea what could be wrong?
laurence
