Most likely your kernel is failing for some reason. CUDA won’t throw and error, so instead it’s best to add error checking after each kernel. (See below).
What device are you using? I suspect that you might be on a newer or older than device than one of the default targets for your compiler version. For example with PGI 18.4, we target cc35, cc50, and cc60 since we default to using CUDA 8.0. Later compiler versions will also add cc70 as well as use CUDA 9.0.
You may need to set the target compute capability for your device such as “-Mcuda=cc70” for a V100.
Note that in our 18.10 release, we’ll default to target the device that’s detected on the compiling system.
% cat test.cuf
module simpleOps_m
contains
attributes(global) subroutine inc(a,b)
implicit none
integer :: a(:)
integer, value :: b
integer :: i, n
i= threadIdx%x
a(i)=a(i)+b
end subroutine inc
end module simpleOps_m
program incTest
use cudafor
use simpleOps_m
implicit none
integer :: b, n=256, rc
integer, allocatable :: a(:)
integer, allocatable, device :: a_d(:)
allocate (a(n), a_d(n))
a=1
b=3
a_d=a
call inc<<<1,n>>>(a_d,b)
rc = cudaGetLastError()
if (rc.ne.0) then
print *, "Error: ", cudaGetErrorString(rc)
endif
a=a_d
if (all(a==4)) &
write(*,*) 'Test Passed'
deallocate (a,a_d)
end program incTest
% pgf90 test.cuf -V18.4 -Mcuda=cc35
% a.out
Error:
invalid device function
% pgf90 test.cuf -V18.4 -Mcuda=cc70
% a.out
Test Passed
Many thanks for your reply. You were right. I verified my compiler version
%pgf90 --versionpgf90
18.4-0 64-bit target on x86-64 Linux -tp sandybridge
PGI Compilers and Tools
Copyright (c) 2018, NVIDIA CORPORATION. All rights reserved.
and my device, which is a quadro K600. Then I compiled the code with the flag -Mcuda=cc30 and got the right answer
% a.out
Test Passed
It was a silly mistake. Next time I will come with a more challenging question ;)
BTW: Do you have some link with the heat example using cuda fortran. It will be very useful to write my app
