What is the name of the port that the gpu plugs into?
I have seen several types of egoism available and I’m trying to figure out if I can add an external GPU.
The external GPU is not supported on Jetson Nano.
Oh ok thanks. What is the port called?
sodimm
Not sure if you are aware, but might be useful to know: The Jetson GPUs are all integrated directly to the memory controller. Doesn’t apply to external GPUs, but this means the default driver itself would not function for any discrete GPU (which uses PCI or some variant under USB-C).
