When using 410+ drivers on Linux with 13 GPU Cards, GPU0 it shows 0% fan speed also using the nvidia-settings shows 0RPM.
On 396 and older it works perfect.
| GPUCurrentFanSpeedRPM is 0 for EVGA GeForce GTX 1080 Ti SC2 HYBRID on Ubuntu 18.04 with nvidia-settings 418.56 and newer | 1 | 562 | June 15, 2019 | |
| Fan speed regression with NVIDIA beta 470.42.01 and RTX 3080 (fans don't stop on idle) | 24 | 9494 | October 26, 2022 | |
| 1050Ti Linux driver always reports fan speed 0, even when 100% | 0 | 33 | May 22, 2026 | |
| GPU Fan ramping to 100% without reason | 3 | 1037 | October 15, 2024 | |
| Fan problem on 1080 Ti | 3 | 2353 | December 22, 2017 | |
| The GPU FAN runs heavily after the process is done. | 19 | 5542 | July 20, 2017 | |
| Recently bought P104-100 card to run headless for learning Cuda, fan spins up to 100% as soon as driver loads. | 3 | 3471 | October 12, 2021 | |
| Unable to manually set-up fan speed / overclocking for second GPU 3060Ti | 2 | 3392 | October 12, 2021 | |
| Any workaround to the 30% fan speed limitation on newer NVIDIA GPUs? | 7 | 14721 | March 22, 2025 | |
| GT440 fan speed can not be lowered below 50% | 1 | 449 | August 22, 2019 |
