Hi i tried to run imx219 Raspi camera on nvidia jetson nano and with some advices i check:
gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM), width=>
int)1920, height=(int)1080,format=(string)NV12, framerate=(fraction)30/1' ! nvoverlaysink
and it runs perfectly good but when i try running detect.py from yolo with my webcam using:
sudo python3 detect.py --weights yolov5n6.pt --conf 0.25 --source 0 --
device 0
i got green screen
detect.py that it uses webcam is :
if webcam:
view_img = check_imshow()
cudnn.benchmark = True # set True to speed up constant image size inference
dataset = LoadStreams(source, img_size=imgsz, stride=stride, auto=pt)
bs = len(dataset) # batch_size
else:
dataset = LoadImages(source, img_size=imgsz, stride=stride, auto=pt)
bs = 1 # batch_size
vid_path, vid_writer = [None] * bs, [None] * bs
and LoadStreams is in file datasets
from utils.datasets import IMG_FORMATS, VID_FORMATS, LoadImages, LoadStreams
so in this file (datasets)
class LoadImages:
# YOLOv5 image/video dataloader, i.e. `python detect.py --source image.jpg/vid.mp4`
def __init__(self, path, img_size=640, stride=32, auto=True):
p = str(Path(path).resolve()) # os-agnostic absolute path
if '*' in p:
files = sorted(glob.glob(p, recursive=True)) # glob
elif os.path.isdir(p):
files = sorted(glob.glob(os.path.join(p, '*.*'))) # dir
elif os.path.isfile(p):
files = [p] # files
else:
raise Exception(f'ERROR: {p} does not exist')
images = [x for x in files if x.split('.')[-1].lower() in IMG_FORMATS]
videos = [x for x in files if x.split('.')[-1].lower() in VID_FORMATS]
ni, nv = len(images), len(videos)
self.img_size = img_size
self.stride = stride
self.files = images + videos
self.nf = ni + nv # number of files
self.video_flag = [False] * ni + [True] * nv
self.mode = 'image'
self.auto = auto
if any(videos):
self.new_video(videos[0]) # new video
else:
self.cap = None
assert self.nf > 0, f'No images or videos found in {p}. ' \
f'Supported formats are:\nimages: {IMG_FORMATS}\nvideos: {VID_FORMATS}'
def __iter__(self):
self.count = 0
return self
def __next__(self):
if self.count == self.nf:
raise StopIteration
path = self.files[self.count]
if self.video_flag[self.count]:
# Read video
self.mode = 'video'
ret_val, img0 = self.cap.read()
while not ret_val:
self.count += 1
self.cap.release()
if self.count == self.nf: # last video
raise StopIteration
else:
self.new_video(path)
self.frame += 1
s = f'video {self.count + 1}/{self.nf} ({self.frame}/{self.frames}) {path}: '
else:
# Read image
self.count += 1
img0 = cv2.imread(path) # BGR
assert img0 is not None, f'Image Not Found {path}'
s = f'image {self.count}/{self.nf} {path}: '
# Padded resize
img = letterbox(img0, self.img_size, stride=self.stride, auto=self.auto)[0]
# Convert
img = img.transpose((2, 0, 1))[::-1] # HWC to CHW, BGR to RGB
img = np.ascontiguousarray(img)
return path, img, img0, self.cap, s
def new_video(self, path):
self.frame = 0
self.cap = cv2.VideoCapture("v4l2src device=/dev/video0 ! video/x-raw, format=YUY2 ! videoconvert ! video/x-raw, format=BGR ! appsink", cv2.CAP_GSTREAMER)
self.frames = int(self.cap.get(cv2.CAP_PROP_FRAME_COUNT))
def _gst_str(self):
return 'nvarguscamerasrc sensor-id=%d ! video/x-raw(memory:NVMM), width=%d, height=%d, format=(string)NV12, framerate=(fraction)%d/1 ! nvvidconv ! video/x-raw, width=(int)%d, height=(int)%d, format=(string)BGRx ! videoconvert ! appsink' % (
self.capture_device, self.capture_width, self.capture_height, self.capture_fps, self.width, self.height)
def __len__(self):
return self.nf # number of files
class LoadWebcam: # for inference
# YOLOv5 local webcam dataloader, i.e. `python detect.py --source 0`
def __init__(self, pipe='0', img_size=640, stride=32):
self.pipe = eval(pipe) if pipe.isnumeric() else pipe
self.cap = cv2.VideoCapture("v4l2src device=/dev/video0 ! video/x-raw, format=YUY2 ! videoconvert ! video/x-raw, format=BGR ! appsink",self.pipe) # video capture object
self.cap.set(cv2.CAP_PROP_BUFFERSIZE, 3) # set buffer size
def __iter__(self):
self.count = -1
return self
def __next__(self):
self.count += 1
if cv2.waitKey(1) == ord('q'): # q to quit
self.cap.release()
cv2.destroyAllWindows()
raise StopIteration
# Read frame
img0 = cv2.flip(img0, 1) # flip left-right
i put below code as ppl with raspi camera problems were told to do
and got green screen. My question is if i did it right or should change something else in this file so yolov5 detecting works.
These are my files:
detect.py (13.3 KB)
datasets.py (44.6 KB)
and these are clean from github:
