Gst-dsexample plugin can't crop and extract detection
• Hardware Platform (GPU)
• DeepStream Version 5.1.0
• TensorRT Version 7.2.2.2
• NVIDIA GPU Driver Version (465.19.01)
I was trying to implement the Gst-dsexample plugin to crop and extract the detection in each frame. I was following this post tutorial:
https://medium.com/@karthickai/using-gstreamer-plugin-to-extract-detected-object-from-nvidia-deepstream-104879cc7154
So basically in the get_converted_mat() method, the following code were added:
  // Use openCV to remove padding and convert RGBA to BGR. Can be skipped if
  // algorithm can handle padded RGBA data.
  in_mat =
      cv::Mat (dsexample->processing_height, dsexample->processing_width,
      CV_8UC4, dsexample->inter_buf->surfaceList[0].mappedAddr.addr[0],
      dsexample->inter_buf->surfaceList[0].pitch);
#if (CV_MAJOR_VERSION >= 4)
  cv::cvtColor (in_mat, *dsexample->cvmat, cv::COLOR_RGBA2BGR);
#else
  cv::cvtColor (in_mat, *dsexample->cvmat, CV_RGBA2BGR);
#endif
  std::string IMpath = "/home/img/";
  IMpath = IMpath + std::to_string(dsexample->frame_num) +"_new" + ".png";
  cv::imwrite(IMpath, *dsexample->cvmat);
But when I run the following pipeline, I always couldn’t get the cropped images in the predefined path, what’s wrong?
The blog is not published by Nvidia. You can ask the author for support.
If you have found anything wrong with deepstream, please tell us how to reproduce the problem.
