gst-inspect is not work properly in DS4.0
I have a question about Gstreamer ,
I used gst-inspect command in DS3.0 because I wanted to check pad and element information
but It does not work in DS4.0 properly so I can’t see any information about deepstream plugin javascript:void(0);
We are able to see the information on DS4.0
nvidia@nvidia-desktop:~/deepstream_sdk_v4.0_jetson/samples/configs/deepstream-app$ gst-inspect-1.0 nvstreammux
Factory Details:
  Rank                     primary (256)
  Long-name                Stream multiplexer
  Klass                    Generic
  Description              N-to-1 pipe stream multiplexing
  Author                   NVIDIA Corporation. Post on Deepstream for Tesla forum for any queries @ https://devtalk.nvidia.com/default/board/209/
Plugin Details:
  Name                     nvdsgst_multistream
  Description              NVIDIA Multistream mux/demux plugin
  Filename                 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so
  Version                  4.0
  License                  Proprietary
  Source module            nvmultistream
  Binary package           NVIDIA Multistream Plugins
  Origin URL               http://nvidia.com/
GObject
 +----GInitiallyUnowned
       +----GstObject
             +----GstElement
                   +----GstNvStreamMux
Pad Templates:
  SINK template: 'sink_%u'
    Availability: On request
    Capabilities:
      video/x-raw(memory:NVMM)
                 format: { (string)NV12, (string)RGBA }
                  width: [ 1, 2147483647 ]
                 height: [ 1, 2147483647 ]
              framerate: [ 0/1, 2147483647/1 ]
      video/x-raw
  SRC template: 'src'
    Availability: Always
    Capabilities:
Element has no clocking capabilities.
Element has no URI handling capabilities.
Pads:
  SRC: 'src'
    Pad Template: 'src'
Element Properties:
  name                : The name of the object
                        flags: readable, writable
                        String. Default: "nvstreammux0"
  parent              : The parent of the object
                        Object of type "GstObject"
  batch-size          : Maximum number of buffers in a batch
                        Unsigned Integer. Range: 0 - 1024 Default: 0
  batched-push-timeout: Timeout in microseconds to wait after the first buffer is available
                        to push the batch even if the complete batch is not formed.
                        Set to -1 to wait infinitely
                        Integer. Range: -1 - 2147483647 Default: -1
  width               : Width of each frame in output batched buffer. This property MUST be set.
                        Unsigned Integer. Range: 0 - 4294967295 Default: 0
  height              : Height of each frame in output batched buffer. This property MUST be set.
  enable-padding      : Maintain input aspect ratio when scaling by padding with black bands.
                        Boolean. Default: false
  gpu-id              : Set GPU Device ID
  live-source         : Boolean property to inform muxer that sources are live.
  num-surfaces-per-frame: Max number of surfaces per frame
                        Unsigned Integer. Range: 1 - 4 Default: 1
  nvbuf-memory-type   : Type of NvBufSurface Memory to be allocated for output buffers
                        flags: readable, writable, changeable only in NULL or READY state
                        Enum "GstNvBufMemoryType" Default: 0, "nvbuf-mem-default"
                           (0): nvbuf-mem-default - Default memory allocated, specific to particular platform
                           (4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
I checked this command below on Xavier after I installed Jetpack 4.2.1 with DS4.0 by using sdkmanager
Could I install something more ?
/opt/nvidia/deepstream/deepstream-4.0/lib/gst-plugins$  gst-inspect-1.0 nvstreammux
No EGL Display
nvbufsurftransform: Could not get EGL display connection
nvidia@nvidia-desktop:/opt/nvidia/deepstream/deepstream-4.0/lib/gst-plugins$  gst-inspect-1.0 dsexample
No EGL Display
Please check if cleaning cache helps:
If the application encounters errors and cannot create Gst elements, remove the GStreamer cache, then try again. To remove the GStreamer cache, enter this command:
$ rm ${HOME}/.cache/gstreamer-1.0/registry.aarch64.bin
Thanks for your help
I found that why doesn’t work it properly," gst-inspect-1.0 nvstreammux"
because I used to send a command by SSH
it was working if used terminal
but I remember that last version DS3.0 on Xavier was wokring this command properly like gst-inspect-1.0 on SSH
Might be permission issue in your created account? We are able to run via ssh:
danel@DANEL-LT1 ~
$ ssh nvidia@10.19.106.152
nvidia@10.19.106.152's password:
Welcome to Ubuntu 18.04.2 LTS (GNU/Linux 4.9.140-tegra aarch64)
 * Documentation:  https://help.ubuntu.com
 * Management:     https://landscape.canonical.com
 * Support:        https://ubuntu.com/advantage
This system has been minimized by removing packages and content that are
not required on a system that users do not log into.
To restore this content, you can run the 'unminimize' command.
77 packages can be updated.
0 updates are security updates.
Last login: Fri Aug  2 15:35:35 2019 from 10.19.93.115
nvidia@nvidia-desktop:~$ gst-inspect-1.0 nvstreammux
Factory Details:
  Rank                     primary (256)
  Klass                    Generic
Plugin Details:
  Version                  4.0
  License                  Proprietary
GObject
       +----GstObject
             +----GstElement
                   +----GstNvStreamMux
Pad Templates:
  SRC template: 'src'
    Capabilities:
    Capabilities:
      video/x-raw
Pads:
  SRC: 'src'
    Pad Template: 'src'
Element Properties:
Thank you for your fast response
I checked your way to use this command was working on SSH properly a few mins ago
I think the connection with X protocol option to Xavier was the problem
ssh -X nvidia@192.168.55.1  // same problem
ssh  nvidia@192.168.55.1  // working properly
Thank you :)
With ‘-X’, please configure export DISPLAY=:1(or 0)
Hi ahyuo79,
Have you tried with our suggestions? Is it working?
Hi kayccc,
now it’s clear and working
Thank you for your help,
