Hi, i have tried to use appsrc and appsink to send and receive video stream and to display as an autovideosink. Below are the used pipelines.
Send:
gst-launch-1.0 videotestsrc ! videoconvert ! x264enc ! h264parse ! appsink name=mysink
Receiveing:
gst-launch-1.0 appsrc name=mysrc ! h264parse ! avdec_h264 ! videoconvert ! autovideosink
The problem is when i try to run these pipelines separately, the video-feed does not display.
What can be the reason for this problem?
Thanks in advance.
You can’t sue appsink appsrc from cli. There are examples online of writing an app with these plugins.
For using appsrc and appsink, you would need to run the pipeline in C code. Please refer to this sample:
Latency issue: nvv4l2h265enc accumulates four images before releasing the first - #3 by DaneLLL
In running gst-lauch-1.0 commands, you may try UDP. Please check Jetson Nano FAQ
Q: Is there an example for running UDP streaming?
system
Closed
6
