gstreamer appsrc "gst_app_src_push_buffer" successfully but no video show in autovideosink
Hi guys .
I have an application which use gstreamer appsink and appsrc.
Here is my pipleline :
filesrc location=/usr/local/1080P.mp4 ! decodebin name=dec ! videoconvert !  appsink name="appsink"
appsrc name="appsrc" ! autovideosink
Then I continuely get buffer from appsink successfully like that
sink_pipeline__->GetLatestSample(&sample);
            caps = gst_sample_get_caps(sample);
            buffer = gst_sample_get_buffer(sample);
            s = gst_caps_get_structure(caps, 0);
            gst_structure_get_int(s, "height", &height);
            gst_structure_get_int(s, "width", &width);
            format = gst_structure_get_string(s, "format");
            size = gst_buffer_get_size(buffer);
            printf("height = %d width =%d format%s size=%d\n", height , width,format,size);
Then I push buffer to appsrc like that
GstFlowReturn ret = gst_app_src_push_buffer((GstAppSrc*)appsrc, buffer); // buffer released automatically
            if(ret == GST_FLOW_OK){
            	std::cout << "GstFlowReturn OK ";
It show me the return value of gst_app_src_push_buffer is GST_FLOW_OK which indicate I have successfully push to the appsrc .
Then why my autovideosink can no show any video even I can see the display window .
Am I miss something important ?
I have successfully solve this problem by changing appsrc pipileline like following :
appsrc caps=video/x-raw,format=(string)I420,width=(int)1280,height=(int)720 block=true name=appsrc | videoconvert ! autovideosink
when I debuging it show me
Error received from element appsrc_name: Internal data flow error.
Debugging information: gstbasesrc.c(2948): gst_base_src_loop (): /GstPipeline:pipeline1/GstAppSrc:appsrc_name:
streaming task paused, reason not-negotiated (-4)
Element filesrc0 changed state from PAUSED to PLAYING.
then I refer http://gstreamer-devel.966125.n4.nabble.com/streaming-task-paused-reason-not-negotiated-4-td4679031.html and add videoconvert to change to its format Then it works.
