Unable to set the pipeline to the playing state ...
Please help me find a solution to this issue:
  • I have YUV data file as input and I should output H264 file, using hardware encoding.
  • I should use c/c++ to write my program.
  • I have already done the following line command and I obtain the h264 as output and I I have succeeded in playing it using vlc.
gst-launch-1.0 filesrc blocksize=345600 location=Basketball.yuv ! 'video/x-raw, width=(int)640, height=(int)360, format=(string)I420, framerate=(fraction)25/1' ! omxh264enc ! 'video/x-h264, stream-format=(string)byte-stream' ! filesink location=results_block_size_345600.h264
-So now I should convert this command line to a code and replace the filesrc by an appsrc, but I obtain error when executing it :
//gcc -Wall $(pkg-config --cflags gstreamer-1.0) YUV_to_H264.c -o yuvtoh264 $(pkg-config --libs gstreamer-1.0) -lgstapp-1.0
#include <gst/gst.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <gst/app/gstappsrc.h>
#define WIDTH 640
#define HEIGHT 360
#define BUFFER_SIZE (WIDTH*HEIGHT*3/2)
/* Structure to contain all our information */
typedef struct _CustomData {
  GstElement *pipeline, *source, *encoder, *filter, *fsink;
  GMainLoop *loop;
  FILE *yuv_file;
} CustomData;
static void cb_need_data (GstElement *source, guint size, CustomData *data)
  static GstClockTime timestamp = 0;
  char* data_pointer;
  //size_t read_bytes;
  GstBuffer *buffer;
  GstFlowReturn ret;
  data_pointer = (char*)malloc (BUFFER_SIZE);
  g_assert(data_pointer != NULL);
  fread(data_pointer, 1 , BUFFER_SIZE, data->yuv_file);
  buffer = gst_buffer_new_wrapped (data_pointer, BUFFER_SIZE);
  free(data_pointer);
  GST_BUFFER_PTS(buffer) = timestamp;
  GST_BUFFER_DTS(buffer) = timestamp;
  //GST_BUFFER_DURATION(buffer) = gst_util_uint64_scale_int (1, GST_SECOND, 1);
  GST_BUFFER_DURATION(buffer) = GST_CLOCK_TIME_NONE;
  timestamp += GST_BUFFER_DURATION (buffer);
  g_signal_emit_by_name (source, "push-buffer", buffer, &ret);
  gst_buffer_unref (buffer);
  if (ret != GST_FLOW_OK) {
    	g_main_loop_quit (data->loop);
gint main (gint argc, gchar *argv[])
  CustomData data;
  GstCaps *input_enc_caps, *output_enc_caps;
  GstStateChangeReturn state_ret;
  long yuv_file_size;
  /*Initialize cumstom data structure */
  memset (&data, 0, sizeof (data));
  /* Initialize GStreamer and create the mainloop */
  gst_init (&argc, &argv);
  data.loop = g_main_loop_new (NULL, FALSE);
  /* Create the elements */
  data.source = gst_element_factory_make ("appsrc", "myapp_source");
  data.encoder = gst_element_factory_make ("omxh264enc", "myapp_encoder");
  data.filter = gst_element_factory_make ("capsfilter", "myapp_filter");
  data.fsink = gst_element_factory_make ("filesink", "myapp_sink");
  /* Create the empty pipeline */
  data.pipeline = gst_pipeline_new ("myapp_pipeline");
  if (!data.pipeline || !data.source || !data.encoder || !data.filter
	|| !data.fsink)
    g_printerr ("Not all elements could be created.\n");
    return -1;
  /* Get a pointer to the YUV input file*/
  data.yuv_file = fopen("/media/ubuntu/6634-3132/Basketball.yuv", "rb");
  g_assert(data.yuv_file != NULL);
  /* Obtain the YUV file size */
  fseek (data.yuv_file , 0 , SEEK_END);
  yuv_file_size = ftell (data.yuv_file);
  rewind (data.yuv_file);
  //printf("\n %ld);
  /* Configure source, filter and fsink */
  input_enc_caps = gst_caps_new_simple ("video/x-raw",
                     "format", G_TYPE_STRING, "I420",
                     "width", G_TYPE_INT, WIDTH,
                     "height", G_TYPE_INT, HEIGHT,
                     "framerate", GST_TYPE_FRACTION, 25, 1, NULL);
  output_enc_caps = gst_caps_new_simple ("video/x-h264",
    			"stream-format", G_TYPE_STRING, "byte-stream", NULL);
  g_object_set (G_OBJECT (data.source), "caps", input_enc_caps,
				   "stream-type", 2,
				   "format", GST_FORMAT_BYTES,
				   "size", (gint64)(yuv_file_size), NULL);
  g_signal_connect (data.source, "need-data", G_CALLBACK (cb_need_data), NULL);
  g_object_set (G_OBJECT (data.filter), "caps", output_enc_caps, NULL);
  g_object_set (G_OBJECT (data.fsink), "location",
	"/media/ubuntu/6634-3132/Basketball.h264", NULL);
  gst_caps_unref (input_enc_caps);
  gst_caps_unref (output_enc_caps);
  //gint64 out_size = gst_app_src_get_size(data.source);
  //g_print("%" G_GINT64_FORMAT, out_size);
  /* Link all elements that can be automatically linked*/
  gst_bin_add_many (GST_BIN (data.pipeline), data.source, data.encoder,
	data.filter, data.fsink, NULL);
  if ((gst_element_link_many (data.source, data.encoder, data.filter,
	data.fsink, NULL)) != TRUE )
    		g_printerr ("Elements could not be linked.\n");
    		gst_object_unref (data.pipeline);
    		return -1;
  /* Start playing the pipeline */
  state_ret = gst_element_set_state (data.pipeline, GST_STATE_PLAYING);
  //g_assert(state_ret == GST_STATE_CHANGE_ASYNC);
  if (state_ret == GST_STATE_CHANGE_FAILURE) {
  	g_printerr ("Unable to set the pipeline to the playing state.\n");
  	return -1;
  /* Set the MainLoop to run */
  g_main_loop_run (data.loop);
  /* clean up */
  fclose (data.yuv_file);
  gst_element_set_state (data.pipeline, GST_STATE_NULL);
  gst_object_unref (GST_OBJECT (data.pipeline));
  g_main_loop_unref (data.loop);
  return 0;
ERRORS :
ubuntu@tegra-ubuntu:~/Desktop$ ./yuvtoh264
Inside NvxLiteH264DecoderLowLatencyInitNvxLiteH264DecoderLowLatencyInit set DPB and MjstreamingInside NvxLiteH265DecoderLowLatencyInitNvxLiteH265DecoderLowLatencyInit set DPB and MjstreamingUnable to set the pipeline to the playing state.
Thanks to help to resolve the isuue.
Regards,
Hi Nostalgie,
We have given a sample at
[url]Errors when using Gstreamer 1.0 appsrc (Thanks for helping me to know the issues) - Jetson TX2 - NVIDIA Developer Forums
