[gstreamer] gstEncoder - pipeline launch string:
appsrc name=mysource ! omxh265enc ! video/x-h265 ! filesink location=1.h265
[gstreamer] gstEncoder - buffer caps string:
video/x-raw-yuv,width=1280,height=720,format=(string)I420,framerate=30/1
(gstCamera:19418): GStreamer-WARNING **: 0.10-style raw video caps are being created. Should be video/x-raw,format=(string)… now.
[gstreamer] gstEncoder - transitioning pipeline to GST_STATE_PLAYING
Inside NvxLiteH264DecoderLowLatencyInitNvxLiteH264DecoderLowLatencyInit set DPB and MjstreamingInside NvxLiteH265DecoderLowLatencyInitNvxLiteH265DecoderLowLatencyInit set DPB and Mjstreaming[gstreamer] initialized gstreamer, version 1.8.3.0
[gstreamer] gstreamer decoder pipeline string:
nvcamerasrc fpsRange=“30.0 30.0” ! video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)I420 ! nvvidconv flip-method=2 ! video/x-raw ! appsink name=mysink
[gstreamer] gstEncoder - AppSrc requesting data (4096 bytes)
gst-camera: successfully initialized video device
width: 1280
height: 720
depth: 12 (bpp)
[gstreamer] gstreamer transitioning pipeline to GST_STATE_PLAYING
Available Sensor modes :
2592 x 1944 FR=30.000000 CF=0x1109208a10 SensorModeType=4 CSIPixelBitDepth=10 DynPixelBitDepth=10
2592 x 1458 FR=30.000000 CF=0x1109208a10 SensorModeType=4 CSIPixelBitDepth=10 DynPixelBitDepth=10
1280 x 720 FR=120.000000 CF=0x1109208a10 SensorModeType=4 CSIPixelBitDepth=10 DynPixelBitDepth=10
[gstreamer] gstreamer changed state from NULL to READY ==> mysink
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter2
[gstreamer] gstreamer changed state from NULL to READY ==> nvvconv0
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter1
[gstreamer] gstreamer changed state from NULL to READY ==> nvcamerasrc0
[gstreamer] gstreamer changed state from NULL to READY ==> pipeline1
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter2
[gstreamer] gstreamer changed state from READY to PAUSED ==> nvvconv0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter1
[gstreamer] gstreamer stream status CREATE ==> src
[gstreamer] gstreamer changed state from READY to PAUSED ==> nvcamerasrc0
[gstreamer] gstreamer changed state from READY to PAUSED ==> pipeline1
[gstreamer] gstreamer stream status ENTER ==> src
[gstreamer] gstreamer msg new-clock ==> pipeline1
[gstreamer] gstreamer msg stream-start ==> pipeline1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter2
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> nvvconv0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> nvcamerasrc0
NvCameraSrc: Trying To Set Default Camera Resolution. Selected 1280x720 FrameRate = 30.000000 …
gst-camera: camera open for streaming
[gstreamer] gstreamer decoder onPreroll
[cuda] cudaAllocMapped 1382400 bytes, CPU 0x102800000 GPU 0x102800000
[cuda] cudaAllocMapped 1382400 bytes, CPU 0x102a00000 GPU 0x102a00000
[cuda] cudaAllocMapped 1382400 bytes, CPU 0x102c00000 GPU 0x102c00000
[cuda] cudaAllocMapped 1382400 bytes, CPU 0x102e00000 GPU 0x102e00000
[cuda] cudaAllocMapped 1382400 bytes, CPU 0x103000000 GPU 0x103000000
[cuda] cudaAllocMapped 1382400 bytes, CPU 0x103200000 GPU 0x103200000
[cuda] cudaAllocMapped 1382400 bytes, CPU 0x103400000 GPU 0x103400000
[cuda] cudaAllocMapped 1382400 bytes, CPU 0x103600000 GPU 0x103600000
[cuda] cudaAllocMapped 1382400 bytes, CPU 0x103800000 GPU 0x103800000
[cuda] cudaAllocMapped 1382400 bytes, CPU 0x103a00000 GPU 0x103a00000
[cuda] cudaAllocMapped 1382400 bytes, CPU 0x103c00000 GPU 0x103c00000
[cuda] cudaAllocMapped 1382400 bytes, CPU 0x103e00000 GPU 0x103e00000
[cuda] cudaAllocMapped 1382400 bytes, CPU 0x104000000 GPU 0x104000000
[cuda] cudaAllocMapped 1382400 bytes, CPU 0x104200000 GPU 0x104200000
[cuda] cudaAllocMapped 1382400 bytes, CPU 0x104400000 GPU 0x104400000
[cuda] cudaAllocMapped 1382400 bytes, CPU 0x104600000 GPU 0x104600000
[cuda] gstreamer camera – allocated 16 ringbuffers, 1382400 bytes each
[gstreamer] gstreamer changed state from READY to PAUSED ==> mysink
[gstreamer] gstreamer msg async-done ==> pipeline1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> mysink
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> pipeline1
gst-camera: recieved new frame CPU=0x0x104000000 GPU=0x0x104000000
[gstreamer] gstreamer changed state from NULL to READY ==> filesink0
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter0
[gstreamer] gstreamer changed state from NULL to READY ==> omxh265enc-omxh265enc0
[gstreamer] gstreamer changed state from NULL to READY ==> mysource
[gstreamer] gstreamer changed state from NULL to READY ==> pipeline0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter0
[gstreamer] gstreamer changed state from READY to PAUSED ==> omxh265enc-omxh265enc0
[gstreamer] gstreamer changed state from READY to PAUSED ==> mysource
[gstreamer] gstreamer changed state from READY to PAUSED ==> pipeline0
[gstreamer] gstreamer msg new-clock ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> omxh265enc-omxh265enc0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> mysource
gst-camera: recieved new frame CPU=0x0x103c00000 GPU=0x0x103c00000
[gstreamer] gstreamer mysource ERROR Internal data flow error.
[gstreamer] gstreamer Debugging info: gstbasesrc.c(2948): gst_base_src_loop (): /GstPipeline:pipeline0/GstAppSrc:mysource:
streaming task paused, reason not-negotiated (-4)
[gstreamer] gstreamer msg stream-start ==> pipeline0
[gstreamer] gstreamer changed state from READY to PAUSED ==> filesink0
gst-camera: recieved new frame CPU=0x0x103a00000 GPU=0x0x103a00000
[gstreamer] gstEncoder - AppSrc signalling enough data
gst-camera: recieved new frame CPU=0x0x103600000 GPU=0x0x103600000
[gstreamer] gstEncoder - pipeline full, skipping frame (1382400 bytes)
gst-camera: un-initializing video device
[gstreamer] gstreamer transitioning pipeline to GST_STATE_NULL
[gstreamer] gstEncoder - shutting down pipeline, sending EOS
^C
