We try to recording video with 3x camera and live view on the display. But execution the command something occur the error message as below:
ERROR: from element /GstPipeline:pipeline0/GstSplitMuxSink:mux/GstQTMux:qtmux0: Could not multiplex stream.
Additional debug info:
gstqtmux.c(4561): gst_qt_mux_add_buffer (): /GstPipeline:pipeline0/GstSplitMuxSink:mux/GstQTMux:qtmux0:
Buffer has no PTS.
EOS on shutdown enabled -- waiting for EOS after Error
Waiting for EOS...
ERROR: from element /GstPipeline:pipeline0/GstNvV4l2CameraSrc:nvv4l2camerasrc0: Internal data stream error.
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstNvV4l2CameraSrc:nvv4l2camerasrc0:
streaming stopped, reason error (-5)
ERROR: from element /GstPipeline:pipeline0/GstQueue:queue0: Internal data stream error.
gstqueue.c(988): gst_queue_handle_sink_event (): /GstPipeline:pipeline0/GstQueue:queue0:
The Gstreamer command:
echo camera1_Recording
gst-launch-1.0 nvv4l2camerasrc device=/dev/video0 ! "video/x-raw(memory:NVMM),width=1920,height=1080,format=(string)YUY2, framerate=30/1" ! queue ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! tee name=t ! queue ! nvv4l2h264enc maxperf-enable=1 profile=0 preset-level=0 bitrate=8000000 ! 'video/x-h264' ! h264parse ! queue ! splitmuxsink name=mux muxer=qtmux max-size-time=300000000000 max-files=34 location="video0_"%d.mp4 \
-e t.! nvegltransform ! nveglglessink window-x=640 window-y=0 window-width=640 window-height=360 -e \
interleave name=i ! audioconvert ! avenc_aac ! aacparse ! mux.audio_0 -e \
alsasrc device=hw:tegrasndt186ref,5 name=ch1 ! audio/x-raw,format=S16LE,rate=44100,channels=4 ! \
audioconvert ! audio/x-raw,channels=1 ! queue ! i.sink_0 \
alsasrc device=hw:tegrasndt186ref,6 name=ch2 ! audio/x-raw,format=S16LE,rate=44100,channels=4 ! \
audioconvert ! audio/x-raw,channels=1 ! queue ! i.sink_1 &
echo camera2_Recording
gst-launch-1.0 nvv4l2camerasrc device=/dev/video1 ! "video/x-raw(memory:NVMM),width=1920,height=1080,format=(string)YUY2, framerate=30/1" ! queue ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! tee name=t ! queue ! nvv4l2h264enc maxperf-enable=1 profile=0 preset-level=0 bitrate=8000000 ! 'video/x-h264' ! h264parse ! queue ! splitmuxsink name=mux muxer=qtmux max-size-time=300000000000 max-files=34 location="video1_"%d.mp4 \
alsasrc device=hw:tegrasndt186ref,7 name=ch1 ! audio/x-raw,format=S16LE,rate=44100,channels=4 ! \
alsasrc device=hw:tegrasndt186ref,2 name=ch2 ! audio/x-raw,format=S16LE,rate=44100,channels=4 ! \
echo camera3_Recording
gst-launch-1.0 nvv4l2camerasrc device=/dev/video2 ! "video/x-raw(memory:NVMM),width=1920,height=1080,format=(string)YUY2, framerate=30/1" ! queue ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! tee name=t ! queue ! nvv4l2h264enc maxperf-enable=1 profile=0 preset-level=0 bitrate=8000000 ! 'video/x-h264' ! h264parse ! queue ! splitmuxsink name=mux muxer=qtmux max-size-time=300000000000 max-files=34 location="video2_"%d.mp4 \
alsasrc device=hw:tegrasndt186ref,4 name=ch1 ! audio/x-raw,format=S16LE,rate=44100,channels=4 ! \
alsasrc device=hw:tegrasndt186ref,3 name=ch2 ! audio/x-raw,format=S16LE,rate=44100,channels=4 ! \
Please help to check and provide the solution.
