We run the test sample n Jetpack 5.1.1 and do not observe the issue:
#include <cstdlib>
#include <gst/gst.h>
#include <gst/gstinfo.h>
#include <gst/app/gstappsink.h>
#include <glib-unix.h>
#include <dlfcn.h>
#include <iostream>
#include <sstream>
#include <thread>
using namespace std;
#define USE(x) ((void)(x))
static GstPipeline *gst_pipeline = nullptr;
static string launch_string;
static unsigned int accumulate_size = 0;
static unsigned int accumulate_count = 0;
static void appsink_eos(GstAppSink * appsink, gpointer user_data)
printf("app sink receive eos\n");
static GstFlowReturn new_buffer(GstAppSink *appsink, gpointer user_data)
GstSample *sample = NULL;
g_signal_emit_by_name (appsink, "pull-sample", &sample,NULL);
if (sample)
GstBuffer *buffer = NULL;
GstCaps *caps = NULL;
GstMapInfo map = {0};
caps = gst_sample_get_caps (sample);
if (!caps)
printf("could not get snapshot format\n");
gst_caps_get_structure (caps, 0);
buffer = gst_sample_get_buffer (sample);
gst_buffer_map (buffer, &map, GST_MAP_READ);
//printf("map.size = %lu\n", map.size);
accumulate_size += map.size;
accumulate_count ++;
if (accumulate_count == 30) {
unsigned int average_rate = (accumulate_size<<3);
printf("bitrate = %d bps \n", average_rate);
accumulate_size = accumulate_count = 0;
gst_buffer_unmap(buffer, &map);
gst_sample_unref (sample);
else
g_print ("could not make snapshot\n");
return GST_FLOW_OK;
int main(int argc, char** argv) {
USE(argc);
USE(argv);
gst_init (&argc, &argv);
GMainLoop *main_loop;
main_loop = g_main_loop_new (NULL, FALSE);
ostringstream launch_stream;
int w = 1920;
int h = 1080;
GstAppSinkCallbacks callbacks = {appsink_eos, NULL, new_buffer};
launch_stream
<< "videotestsrc is-live=1 ! nvvidconv ! "
<< "video/x-raw(memory:NVMM), width="<< w <<", height="<< h <<", framerate=30/1,format=(string)NV12 ! "
<< "nvv4l2h265enc name=video_enc ! video/x-h265,stream-format=byte-stream ! "
<< "appsink name=mysink ";
launch_string = launch_stream.str();
g_print("Using launch string: %s\n", launch_string.c_str());
GError *error = nullptr;
gst_pipeline = (GstPipeline*) gst_parse_launch(launch_string.c_str(), &error);
if (gst_pipeline == nullptr) {
g_print( "Failed to parse launch: %s\n", error->message);
return -1;
if(error) g_error_free(error);
GstElement *encoder = gst_bin_get_by_name(GST_BIN(gst_pipeline), "video_enc");
if(!GST_IS_ELEMENT(encoder)) {
g_print( "Failed to get encoder from pipeline \n");
return -1;
GstElement *appsink_ = gst_bin_get_by_name(GST_BIN(gst_pipeline), "mysink");
gst_app_sink_set_callbacks (GST_APP_SINK(appsink_), &callbacks, NULL, NULL);
gst_element_set_state((GstElement*)gst_pipeline, GST_STATE_PLAYING);
sleep(5);
GstFlowReturn ret;
g_print("signal force-IDR \n");
g_signal_emit_by_name (G_OBJECT(encoder), "force-IDR", NULL, &ret);
sleep(10);
//send EOS
GstPad *pad = gst_element_get_static_pad(encoder, "sink");
gst_pad_send_event(pad, gst_event_new_eos());
gst_object_unref(pad);
// Wait for EOS message
GstBus *bus = gst_pipeline_get_bus(GST_PIPELINE(gst_pipeline));
gst_bus_poll(bus, GST_MESSAGE_EOS, GST_CLOCK_TIME_NONE);
gst_element_set_state((GstElement*)gst_pipeline, GST_STATE_NULL);
gst_object_unref(GST_OBJECT(gst_pipeline));
g_main_loop_unref(main_loop);
g_print("going to exit \n");
return 0;
Build command:
$ g++ -Wall -std=c++11 test.cpp -o test $(pkg-config --cflags --libs gstreamer-app-1.0)
Please try it in your setup and see if it can be run successfully.
