Hello everyone ,I want to test media server, but when I use GStreamer Daemon - building a media server in under 30 minutes I get this error .
Creating camera pipeline
Could not connect to localhost: Connection refused
i’m new in Gstreamer an i need your Help please .
It is not clear about building a media server. You may share more information about what you would like to do. A general case is to launch RTSP server through test-launch. You may refer to
Thanks for your replay , i have a problem while executing the samples of creating camera ,creating streaming …
i got this error and i don’t now how to resolve it .
Gstd version 0.10.0Copyright (C) 2015-2020 RidgeRun (https://www.ridgerun.com)0:06:48.023746719 10098 0x557002bde0 ERROR gstdlist gstd_list.c:278:gstd_list_delete:GstdList@0x556fe0d5b0 The resource “streaming” doesn’t exists in "pipelines"0:06:48.130380573 10098 0x557002bde0 ERROR gstdpipeline gstd_pipeline.c:504:gstd_pipeline_create:GstdPipeline@0x7f9c105830 Unable to create pipeline: noproperty “enable-sync” in element "streaming"0:06:48.130470677 10098 0x557002bde0 ERROR gstdlist gstd_list.c:233:gstd_list_create:GstdList@0x556fe0d5b0 Could not create the resource “streaming” on "pipelines"0:09:09.802901040 10098 0x557002bd90 ERROR gstdlist gstd_list.c:278:gstd_list_delete:GstdList@0x556fe0d5b0 The resource “camera” doesn’t exists in “pipelines"0:09:09.894201925 10098 0x557002bd90 ERROR gstdpipeline gstd_pipeline.c:504:gstd_pipeline_create:GstdPipeline@0x7f9c1058e0 Unable to create pipeline: could not link nvarguscamerasrc0 to nvvconv0, nvarguscamerasrc0 can’t handle caps video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)I420, framerate=(fraction)30/10:09:09.894297706 10098 0x557002bd90 ERROR gstdlist gstd_list.c:233:gstd_list_create:GstdList@0x556fe0d5b0 Could not create the resource “camera” on"pipelines”
i have launch 2 Terminals: First one for the gsdt -D and the second for the gstd-client, and i have tried to compile the examples already on the gstd-30min-server but i got the same Error.
what i missing??
how can i lauch that correctly
0:00:51.923824634 17634 0x55a2537d90 ERROR gstdlist gstd_list.c:278:gstd_list_delete:GstdList@0x55a23195b0 The resource “camera” doesn’t exists in “pipelines”
0:00:52.340396832 17634 0x55a2537d90 ERROR gstdpipeline gstd_pipeline.c:504:gstd_pipeline_create:GstdPipeline@0x7f68106800 Unable to create pipeline: could not link nvarguscamerasrc0 to nvvconv0, nvarguscamerasrc0 can’t handle caps video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)I420, framerate=(fraction)30/1
the pipeline for creating the camera : gst-client pipeline_delete camera
gst-client pipeline_create camera
nvarguscamerasrc ! video/x-raw(memory:NVMM),width=1920,height=1080,format=I420,framerate=30/1 !
nvvidconv ! video/x-raw !
interpipesink name=camera sync=false
And for playing is :gst-client pipeline_play camera
