Getting these errors inconsistently when writing frames to mp4 using opencv and gstreamer on NX and 4.4.1 - It used to work just fine on older version of jetpack.
The pipline is as follows
pipeline = "appsrc ! videoconvert ! nvvidconv ! video/x-raw(memory:NVMM), format=(string)NV12, framerate="
+ std::to_string(static_cast<int>(video_data.fps)) + "/1, width=" + std::to_string(frame_width_) +
", height="+ std::to_string(frame_height_) + " ! " + "omxh264enc bitrate=8000000 ! h264parse !" +
" mp4mux ! filesink location=" + video_file.path + " sync=false";
cv::VideoWriter writer(pipeline, fourcc, static_cast<int>(video_data.fps), cv::Size(frame_width_, frame_height_));
writer.write(img);
Sometimes it works but mostly I get this result for every frame pushed into the opencv writer. The images being input are valid as I can visualize them separately.
WARN:1] global /home/nvidia/host/build_opencv/nv_opencv/modules/videoio/src/cap_gstreamer.cpp (1757) handleMessage OpenCV | GStreamer warning: Embedded video playback halted; module appsrc2 reported: Internal data stream error.
[ WARN:1] global /home/nvidia/host/build_opencv/nv_opencv/modules/videoio/src/cap_gstreamer.cpp (1663) writeFrame OpenCV | GStreamer warning: Error pushing buffer to GStreamer pipeline
Any idea what is going on? The fact that it isn’t every time is confusing to me. I am also running hw jpeg encoding and decoding on other threads and that is working.
When it works I just see this:
Framerate set to : 20 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
H264: Profile = 66, Level = 40
