I’m trying the below pipeline as follows:
gst-launch-1.0 -e videotestsrc pattern=black ! video/x-raw,width=320,height=240 ! nvvidconv ! queue ! tee name=t5 ! queue ! comp1.sink_0 v4l2src device=/dev/presentation ! queue ! tee name=t1 ! video/x-raw, width=1920, height=1080, framerate=60/1 ! videorate ! video/x-raw, width=1920, height=1080, framerate=30/1 ! nvvidconv ! queue ! “video/x-raw(memory:NVMM),width=960,height=540,format=NV12” ! queue ! comp1.sink_1 v4l2src device=/dev/exCAM io-mode=2 ! tee name=t2 ! queue ! image/jpeg,width=1920,height=1080,framerate=30/1 ! videorate ! image/jpeg,width=1920,height=1080,framerate=30/1 ! nvv4l2decoder mjpeg=1 ! nvvidconv ! queue ! “video/x-raw(memory:NVMM),width=960,height=540,format=NV12” ! queue ! comp1.sink_2 t2. ! queue ! image/jpeg,width=1920,height=1080,framerate=30/1 ! videorate ! image/jpeg,width=1920,height=1080,framerate=30/1 ! nvv4l2decoder mjpeg=1 ! nvvidconv ! queue ! “video/x-raw(memory:NVMM),width=960,height=540,format=NV12” ! queue ! comp1.sink_3 gdkpixbufoverlay location=logo-.png ! videoconvert ! imagefreeze ! queue ! comp1.sink_4 nvcompositor name=comp1 sink_0::width=1920 sink_0::height=1080 sink_1::xpos=0 sink_1::ypos=295 sink_1::width=970 sink_1::height=540 sink_2::xpos=970 sink_2::ypos=295 sink_2::width=960 sink_2::height=540 sink_3::xpos=0 sink_3::ypos=0 sink_3::width=1950 sink_3::height=270 sink_4::ypos=860 sink_4::width=1950 sink_4::height=270 ! nvvidconv ! nvoverlaysink display-id=1
The comp 3 is what i’m trying to display the image
When i try to run the above pipeline, it does not throw an error and it does not show the preview as well. but, when i tried to run the pipeline, the following info appeared
Setting pipeline to PAUSED …
Opening in BLOCKING MODE
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
NvMMLiteOpen : Block : BlockType = 277
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 277
^Chandling interrupt.
Interrupt: Stopping pipeline …
EOS on shutdown enabled – Forcing EOS on the pipeline
is there any other method to eliminate this and get the preview?
Thanks in advance !
