The above pipeline works, but I think there is a lot of unnecesary plugins I’m using. What I want to achieve is very simple, just send the image to the rtspclientsink with the height, width, 1 framerate per second.
This takes a lot of CPU Eventually I want to be able to view the localhost stream. What am I doing wrong?
Sorry for missed this topic, is it still an issue now?
jpegdec&videoconvert&x264end can be replaced by NVidia hardware accelerated plugins, which can save a lot of CPU resources.
Thank you for your reply,
Yes it’s still an issue,
Let’s think about it for a moment, all I want to do is send an image from a single file src, to be streamed via rtsp or rtmp, why all these middle plugins that is going to consume a lot of things?
Currently I’m learning C language to understand the offical tutorials, but I’m litreally in hell to use all of these plugins to produce a single stream contains a single image that should be refreshed x amount of seconds…
Waiting for an answer!
you can use HW jpeg decoding and HW h264 encoding. here is a sample:
gst-launch-1.0 filesrc location=/home/2.jpg ! jpegparse ! nvv4l2decoder ! nvvideoconvert ! ‘video/x-raw(memory:NVMM),format=I420’ ! nvv4l2h264enc bitrate=1000000 ! filesink location=test.264
I know I’m inside Nvidia forums :D And it’s quite embarrassing, I want to run the above pipeline on Raspberry PI 4 using Debian 11 or any operating system that doesn’t depend on any NVIDIA hardware.
Also correct me if I’m wrong
As you know, NVIDIA HW plugins are based on NVIDIA GPU. This issue would be outside of Deepstream, You could try asking in the Raspberry PI 4 community.
