Gstreamer Interpipe wont run in jetson nano
I have successfully installed gstreamer interpipes.
I tried the below commands to run a test
gst-launch-1.0 v4l2src device=/dev/video0 ! interpipesink name=vid
gst-launch-1.0 interpipesrc listen-to=vid ! xvimagesink
I an unable to see a preview
Below is the output when the above command is executed
Setting pipeline to PAUSED …
Pipeline is PREROLLING …
What can be the solution for this?
My application is to preview, record and stream the video from the source. I tried tee element but when the stream failed the whole pipeline stops. Hence I started to look into interpipes.
How can I achieve this using gstreamer interpipes?
These are custom plugins. Please contact RidgeRun to get further help.
Hello @pulzappcheck890,
RidgeRun is the developer of the gst-interpipe plugin. We can provide you further help with the plugin.
Please follow these instructions:
1- Install the GStreamer Daemon needed to handle easily the interpipes pipelines. Follow instructions here:
https://developer.ridgerun.com/wiki/index.php?title=GStreamer_Daemon_-_Building_GStreamer_Daemon
2- After installation, run the gstreamer daemon with the following command
gstd
3- Create the camera src pipeline (pipe1), defining caps and decoding, here we are using a jpeg camera, therefore we need parse and decoding, for example:
gst-client pipeline_create pipe1 v4l2src device=/dev/video0 ! image/jpeg,width=1920,height=1080,framerate=30/1 ! jpegparse ! jpegdec ! interpipesink name=vid sync=false
4- Create the receiving pipeline (pipe2)
gst-client pipeline_create pipe2 interpipesrc listen-to=vid ! xvimagesink sync=false
5- Start the pipelines in the following order
gst-client pipeline_play pipe1
gst-client pipeline_play pipe2
Regards,
Fabian
www.ridgerun.com
Thank you @fabian.solano , I’ve tried the below method.
My requirement is to run two or more separate pipelines using a single source, and if one pipeline fails the others must not stop and the failed pipeline must have the ability to be restarted without affecting the running pipelines.
I tried the below example
I have a camera source and started to play and record the pipeline using the below command using gstreamer interpipes.
gst-launch-1.0 -e v4l2src device=/dev/video0 ! interpipesink name=vid interpipesrc listen-to=vid ! ‘video/x-raw, framerate=30/1, format=YUY2’ ! nvvidconv ! ‘video/x-raw(memory:NVMM),format=NV12’ ! omxh264enc ! mpegtsmux name=mux ! filesink location=usb.ts interpipesrc listen-to=vid ! xvimagesink
The pipeline is working the recording happens while being played.
Problem:
As soon as I close the preview the recording wont stop but the within 2-3minutes RAM usage of the jetson nano increases and the whole thing gets stuck.
Is there a method to solve this?
Thank You
Hi @fabian.solano,
I successfully installed gstd and tried the below pipelines.
gst-client pipeline_create pipe1 v4l2src device=/dev/video0 ! interpipesink name=vid sync=false
gst-client pipeline_create pipe3 interpipesrc listen-to=vid ! ‘video/x-raw, framerate=30/1, format=YUY2’ ! nvvidconv ! ‘video/x-raw(memory:NVMM),format=NV12’ ! omxh264enc ! mpegtsmux name=mux ! filesink location=cam.ts sync=false
And started the pipeleines in the following order
gst-client pipeline_play pipe3
when gst-client pipeline_play pipe3 is executed i get the bellow error
“code” : 14,
“description” : “State error”,
“response” : null
How can I solve this?
Hi @pulzappcheck890,
Probably you are getting “State error”, because the pipeline is not linking correctly. Please try to run with the environment flag GST_DEBUG=4, and provide the log of the error.
Regards,
Fabian
www.ridgerun.com
I tried it with GST_DEBUG=4 as below
GST_DEBUG=4 gst-client pipeline_play pipe3
Still I get the same error
Below I have attached the response when the pipe3 is created
“code” : 0,
“description” : “Success”,
“response” : {
“properties” : [
“name” : “name”,
“value” : “"pipe3"”,
“param” : {
“description” : “The name of the current Gstd session”,
“type” : “gchararray”,
“access” : “((GstdParamFlags) READ | 234)”
“name” : “description”,
“value” : “"interpipesrc listen-to=vid ! video/x-raw, framerate=30/1, format=YUY2 ! nvvidconv ! video/x-raw(memory:NVMM),format=NV12 ! omxh264enc ! mpegtsmux name=mux ! filesink location=cam.ts sync=false"”,
“param” : {
“description” : “The gst-launch like pipeline description”,
“name” : “elements”,
“value” : “((GstdList*) 0x7fa0145ab0)”,
“param” : {
“description” : “The elements in the pipeline”,
“type” : “GstdList”,
“access” : “((GstdParamFlags) READ | 224)”
“name” : “bus”,
“value” : “((GstdPipelineBus*) 0x7fa02414e0)”,
“param” : {
“description” : “The bus callback for this element”,
“type” : “GstdPipelineBus”,
“name” : “state”,
“value” : “((GstdState*) 0x7fa022b6a0)”,
“param” : {
“description” : “The state of the pipeline”,
“type” : “GstdState”,
“access” : “((GstdParamFlags) READ | UPDATE | 226)”
“name” : “event”,
“value” : “((GstdEventHandler*) 0x7fa023d000)”,
“param” : {
“description” : “The event handler of the pipeline”,
“type” : “GstdEventHandler”,
“name” : “position”,
“value” : 0,
“param” : {
“description” : “The query position of the tion Error
Jetson Nano
pytorch
1 14 1h
There are 168 new topics remaining, or browse other topics in
Jetson Nano
Copyright © 2020 NVIDIA Corporation Legal Information Privacy Policy Contact Cookie policy
pipeline”,
“type” : “gint64”,
“name” : “duration”,
“value” : 0,
“param” : {
“description” : “The duration of the media stream pipeline”,
“type” : “gint64”,
“name” : “graph”,
“value” : “"digraph pipeline {\n rankdir=LR;\n fontname=\"sans\";\n fontsize=\"10\";\n labelloc=t;\n nodesep=.1;\n ranksep=.2;\n label=\"\\npipe3\\n[0]\";\n node [style=\"filled,rounded\", shape=box, fontsize=\"9\", fontname=\"sans\", margin=\"0.0,0.0\"];\n edge [labelfontsize=\"6\", fontsize=\"9\", fontname=\"monospace\"];\n \n legend [\n pos=\"0,0!\",\n margin=\"0.05,0.05\",\n style=\"filled\",\n label=\"Legend\\lElement-States: [~] void-pending, [0] null, [-] ready, [=] paused, [>] playing\\lPad-Activation: [-] none, [>] push, [<] pull\\lPad-Flags: [b]locked, [f]lushing, [b]locking, [E]OS; upper-case is set\\lPad-Task: [T] has started task, [t] has paused task\\l\",\n ];\n subgraph cluster_capsfilter1_0x7fa022c440 {\n fontname=\"Bitstream Vera Sans\";\n fontsize=\"8\";\n style=\"filled,rounded\";\n color=black;\n label=\"GstCapsFilter\\ncapsfilter1\\n[0]\\nparent=(GstPipeline) pipe3\\ncaps=video/x-raw(memory:NVMM), format=(string)NV12\";\n subgraph cluster_capsfilter1_0x7fa022c440_sink {\n label=\"\";\n style=\"invis\";\n capsfilter1_0x7fa022c440_sink_0x7fa022e150 [color=black, fillcolor=\"#aaaaff\", label=\"sink\\n[-][bFb]\", height=\"0.2\", style=\"filled,solid\"];\n }\n\n subgraph cluster_capsfilter1_0x7fa022c440_src {\n label=\"\";\n style=\"invis\";\n capsfilter1_0x7fa022c440_src_0x7fa022e3a0 [color=black, fillcolor=\"#ffaaaa\", label=\"src\\n[-][bFb]\", height=\"0.2\", style=\"filled,solid\"];\n }\n\n capsfilter1_0x7fa022c440_sink_0x7fa022e150 → capsfilter1_0x7fa022c440_src_0x7fa022e3a0 [style=\"invis\"];\n fillcolor=\"#aaffaa\";\n }\n\n capsfilter1_0x7fa022c440_src_0x7fa022e3a0 → omxh264enc_omxh264enc0_0x7fa021a670_sink_0x7fa00270a0 [labeldistance=\"10\", labelangle=\"0\", label=\" \", taillabel=\"ANY\", headlabel=\"video/x-raw(memory:NVMM)\\l format: { (string)I420, (str… }\\l width: [ 1, 2147483647 ]\\l height: [ 1, 2147483647 ]\\l framerate: [ 0/1, 2147483647/1 ]\\lvideo/x-raw\\l format: { (string)I420, (str… }\\l width: [ 1, 2147483647 ]\\l height: [ 1, 2147483647 ]\\l framerate: [ 0/1, 2147483647/1 ]\\l\"]\n subgraph cluster_capsfilter0_0x7fa022c100 {\n fontname=\"Bitstream Vera Sans\";\n fontsize=\"8\";\n style=\"filled,rounded\";\n color=black;\n label=\"GstCapsFilter\\ncapsfilter0\\n[0]\\nparent=(GstPipeline) pipe3\\ncaps=video/x-raw, framerate=(fraction)30/1, format=(string)YUY2\";\n subgraph cluster_capsfilter0_0x7fa022c100_sink {\n label=\"\";\n style=\"invis\";\n capsfilter0_0x7fa022c100_sink_0x7fa00279e0 [color=black, fillcolor=\"#aaaaff\", label=\"sink\\n[-][bFb]\", height=\"0.2\", style=\"filled,solid\"];\n }\n\n subgraph cluster_capsfilter0_0x7fa022c100_src {\n label=\"\";\n style=\"invis\";\n capsfilter0_0x7fa022c100_src_0x7fa0027c30 [color=black, fillcolor=\"#ffaaaa\", label=\"src\\n[-][bFb]\", height=\"0.2\", style=\"filled,solid\"];\n }\n\n capsfilter0_0x7fa022c100_sink_0x7fa00279e0 → capsfilter0_0x7fa022c100_src_0x7fa0027c30 [style=\"invis\"];\n fillcolor=\"#aaffaa\";\n }\n\n capsfilter0_0x7fa022c100_src_0x7fa0027c30 → nvvconv0_0x7fa0212110_sink_0x7fa0026c00 [labeldistance=\"10\", labelangle=\"0\", label=\" \", taillabel=\"ANY\", headlabel=\"video/x-raw(memory:NVMM)\\l format: { (string)I420, (str… }\\l width: [ 1, 2147483647 ]\\l height: [ 1, 2147483647 ]\\l framerate: [ 0/1, 2147483647/1 ]\\lvideo/x-raw\\l format: { (string)I420, (str… }\\l width: [ 1, 2147483647 ]\\l height: [ 1, 2147483647 ]\\l framerate: [ 0/1, 2147483647/1 ]\\l\"]\n subgraph cluster_filesink0_0x7fa0228f90 {\n fontname=\"Bitstream Vera Sans\";\n fontsize=\"8\";\n style=\"filled,rounded\";\n color=black;\n label=\"GstFileSink\\nfilesink0\\n[0]\\nparent=(GstPipeline) pipe3\\nsync=FALSE\\nlocation=\\\"cam.ts\\\"\";\n subgraph cluster_filesink0_0x7fa0228f90_sink {\n label=\"\";\n style=\"invis\";\n filesink0_0x7fa0228f90_sink_0x7fa0027790 [color=black, fillcolor=\"#aaaaff\", label=\"sink\\n[-][bFb]\", height=\"0.2\", style=\"filled,solid\"];\n }\n\n fillcolor=\"#aaaaff\";\n }\n\n subgraph cluster_mux_0x7fa021e060 {\n fontname=\"Bitstream Vera Sans\";\n fontsize=\"8\";\n style=\"filled,rounded\";\n color=black;\n label=\"MpegTsMux\\nmux\\n[0]\\nparent=(GstPipeline) pipe3\";\n subgraph cluster_mux_0x7fa021e060_sink {\n label=\"\";\n style=\"invis\";\n mux_0x7fa021e060_sink_65_0x7fa022e5f0 [color=black, fillcolor=\"#aaaaff\", label=\"sink_65\\n[-][bFb]\", height=\"0.2\", style=\"filled,dashed\"];\n }\n\n subgraph cluster_mux_0x7fa021e060_src {\n label=\"\";\n style=\"invis\";\n mux_0x7fa021e060_src_0x7fa0027540 [color=black, fillcolor=\"#ffaaaa\", label=\"src\\n[-][bFb]\", height=\"0.2\", style=\"filled,solid\"];\n }\n\n mux_0x7fa021e060_sink_65_0x7fa022e5f0 → mux_0x7fa021e060_src_0x7fa0027540 [style=\"invis\"];\n fillcolor=\"#aaffaa\";\n }\n\n mux_0x7fa021e060_src_0x7fa0027540 → filesink0_0x7fa0228f90_sink_0x7fa0027790 [labeldistance=\"10\", labelangle=\"0\", label=\" \", taillabel=\"video/mpegts\\l systemstream: true\\l packetsize: { (int)188, (int)192 }\\l\", headlabel=\"ANY\"]\n subgraph cluster_omxh264enc_omxh264enc0_0x7fa021a670 {\n fontname=\"Bitstream Vera Sans\";\n fontsize=\"8\";\n style=\"filled,rounded\";\n color=black;\n label=\"GstOMXH264Enc-omxh264enc\\nomxh264enc-omxh264enc0\\n[0]\\nparent=(GstPipeline) pipe3\\niframeinterval=0\";\n subgraph cluster_omxh264enc_omxh264enc0_0x7fa021a670_sink {\n label=\"\";\n style=\"invis\";\n omxh264enc_omxh264enc0_0x7fa021a670_sink_0x7fa00270a0 [color=black, fillcolor=\"#aaaaff\", label=\"sink\\n[-][bFb]\", height=\"0.2\", style=\"filled,solid\"];\n }\n\n subgraph cluster_omxh264enc_omxh264enc0_0x7fa021a670_src {\n label=\"\";\n style=\"invis\";\n omxh264enc_omxh264enc0_0x7fa021a670_src_0x7fa00272f0 [color=black, fillcolor=\"#ffaaaa\", label=\"src\\n[-][bFb]\", height=\"0.2\", style=\"filled,solid\"];\n }\n\n omxh264enc_omxh264enc0_0x7fa021a670_sink_0x7fa00270a0 → omxh264enc_omxh264enc0_0x7fa021a670_src_0x7fa00272f0 [style=\"invis\"];\n fillcolor=\"#aaffaa\";\n }\n\n omxh264enc_omxh264enc0_0x7fa021a670_src_0x7fa00272f0 → mux_0x7fa021e060_sink_65_0x7fa022e5f0 [labeldistance=\"10\", labelangle=\"0\", label=\" \", taillabel=\"video/x-h264\\l width: [ 16, 4096 ]\\l height: [ 16, 4096 ]\\l stream-format: { (string)byte-strea… }\\l alignment: au\\l\", headlabel=\"video/mpeg\\l parsed: true\\l mpegversion: { (int)1, (int)2, (i… }\\l systemstream: false\\lvideo/x-dirac\\limage/x-jpc\\lvideo/x-h264\\l stream-format: byte-stream\\l alignment: { (string)au, (strin… }\\lvideo/x-h265\\l stream-format: byte-stream\\l alignment: { (string)au, (strin… }\\laudio/mpeg\\l parsed: true\\l mpegversion: { (int)1, (int)2 }\\laudio/mpeg\\l framed: true\\l mpegversion: 4\\l stream-format: adts\\laudio/mpeg\\l mpegversion: 4\\l stream-format: raw\\laudio/x-lpcm\\l width: { (int)16, (int)20, … }\\l rate: { (int)48000, (int)9… }\\l channels: [ 1, 8 ]\\l dynamic_range: [ 0, 255 ]\\l emphasis: { (boolean)false, (b… }\\l mute: { (boolean)false, (b… }\\laudio/x-ac3\\l framed: true\\laudio/x-dts\\l framed: true\\laudio/x-opus\\l channels: [ 1, 8 ]\\l channel-mapping-family: { (int)0, (int)1 }\\lsubpicture/x-dvb\\lapplication/x-teletext\\lmeta/x-klv\\l parsed: true\\limage/x-jpc\\l profile: [ 0, 49151 ]\\l\"]\n subgraph cluster_nvvconv0_0x7fa0212110 {\n fontname=\"Bitstream Vera Sans\";\n fontsize=\"8\";\n style=\"filled,rounded\";\n color=black;\n label=\"Gstnvvconv\\nnvvconv0\\n[0]\\nparent=(GstPipeline) pipe3\";\n subgraph cluster_nvvconv0_0x7fa0212110_sink {\n label=\"\";\n style=\"invis\";\n nvvconv0_0x7fa0212110_sink_0x7fa0026c00 [color=black, fillcolor=\"#aaaaff\", label=\"sink\\n[-][bFb]\", height=\"0.2\", style=\"filled,solid\"];\n }\n\n subgraph cluster_nvvconv0_0x7fa0212110_src {\n label=\"\";\n style=\"invis\";\n nvvconv0_0x7fa0212110_src_0x7fa0026e50 [color=black, fillcolor=\"#ffaaaa\", label=\"src\\n[-][bFb]\", height=\"0.2\", style=\"filled,solid\"];\n }\n\n nvvconv0_0x7fa0212110_sink_0x7fa0026c00 → nvvconv0_0x7fa0212110_src_0x7fa0026e50 [style=\"invis\"];\n fillcolor=\"#aaffaa\";\n }\n\n nvvconv0_0x7fa0212110_src_0x7fa0026e50 → capsfilter1_0x7fa022c440_sink_0x7fa022e150 [labeldistance=\"10\", labelangle=\"0\", label=\" \", taillabel=\"video/x-raw(memory:NVMM)\\l format: { (string)I420, (str… }\\l width: [ 1, 2147483647 ]\\l height: [ 1, 2147483647 ]\\l framerate: [ 0/1, 2147483647/1 ]\\lvideo/x-raw\\l format: { (string)I420, (str… }\\l width: [ 1, 2147483647 ]\\l height: [ 1, 2147483647 ]\\l framerate: [ 0/1, 2147483647/1 ]\\l\", headlabel=\"ANY\"]\n subgraph cluster_interpipesrc1_0x7fa0150c30 {\n fontname=\"Bitstream Vera Sans\";\n fontsize=\"8\";\n style=\"filled,rounded\";\n color=black;\n label=\"GstInterPipeSrc\\ninterpipesrc1\\n[0]\\nparent=(GstPipeline) pipe3\\nemit-signals=FALSE\\nlisten-to=\\\"vid\\\"\";\n subgraph cluster_interpipesrc1_0x7fa0150c30_src {\n label=\"\";\n style=\"invis\";\n interpipesrc1_0x7fa0150c30_src_0x7fa00269b0 [color=black, fillcolor=\"#ffaaaa\", label=\"src\\n[-][bFb]\", height=\"0.2\", style=\"filled,solid\"];\n }\n\n fillcolor=\"#ffaaaa\";\n }\n\n interpipesrc1_0x7fa0150c30_src_0x7fa00269b0 → capsfilter0_0x7fa022c100_sink_0x7fa00279e0 [label=\"ANY\"]\n}\n"”,
“param” : {
“description” : “The pipeline graph on GraphViz dot format”,
“name” : “verbose”,
“value” : false,
“param” : {
“description” : “Verbose state for the media stream pipeline”,
“type” : “gboolean”,
“access” : “((GstdParamFlags) READ | 2)”
Are you able to validate this pipeline using gst-launch-1.0 just to discard it is something related with pipeline tuning? Otherwise I would recommend sending an inquiry to support@ridgerun.com
Regards,
Fabian
www.ridgerun.com
Hi @fabian.solano
I was able to sort out the State error problem. The issue was the file location, It must be changed to a location other than the root.
Now the pipeline starts but a 0 byte file is created, What can be the problem for this?
Thank You
Hi @fabian.solano
I tried the below pipelines
gst-client pipeline_create pipe3 interpipesrc listen-to=vid ! ‘video/x-raw, framerate=30/1, format=YUY2’ ! nvvidconv ! ‘video/x-raw(memory:NVMM),format=NV12’ ! omxh264enc ! mpegtsmux name=mux ! filesink location=/tmp/cam.ts sync=false
pipe3(file recording) state wont change to PLAYING state its always on the READY state and a file is made which is 0bytes
Thank You
Hi @fabian.solano,
I am trying a picture in picture pipeline recording
gst-client pipeline_create pipe5 interpipesrc name=src format=time listen-to=ch1 accept-events=false accept-eos-events=false enable-sync=false caps="video/x-raw, format=(string)YUY2, width=(int)1920, height=(int)1080, framerate=(fraction)30/1" ! comp.sink_0 interpipesrc name=src2 format=time listen-to=ch2 accept-events=false accept-eos-events=false enable-sync=false caps="video/x-raw, framerate=(fraction)30/1" ! comp.sink_1 nvcompositor name=comp sink_0::xpos=0 sink_0::ypos=0 sink_1::xpos=1500 sink_1::ypos=800 sink_1::width=320 sink_1::height=240 ! nvvidconv ! nvv4l2h264enc maxperf-enable=1 bitrate=4000000 profile=4 ! h264parse ! mux. pulsesrc device="alsa_input.usb-VXIS_Inc_ezcap_U3_capture-02.analog-stereo" ! 'audio/x-raw, format=(string)S16LE, layout=(string)interleaved, rate=44100, channels=(int)2' ! queue ! audioconvert ! voaacenc ! aacparse ! mpegtsmux name=mux ! filesink location="/tmp/pipinters.ts"
“code” : 2,
“description” : “Bad pipeline description”,
“response” : null
I get the above eroor when executed the gstd command. What can be the reason?
The
Error is related with syntax error or a pipeline that cannot be build due missing elements or incorrect parameters. Please always try to verify your pipeline with gst-launch, and after that use it with gstd.
Regards,
Fabian
www.ridgerun.com
Hi @fabian.solano
I was able to sort it out the problem was incorrect parameters used. Thank you for your help
I am trying to do the following tasks using interpipe and jetson nano.
I have 2 video sources usb/rtsp
Below are my tasks that has to run simultaneously
  1. 1080p PIP recording to usb disk
  2. 1080p PIP stream rtmp
  3. Preview PIP in a small window(144x80)
  4. Preview video source 1 in a small window(144x80)
  5. Preview video source 2 in a small window(144x80)
All 1 2 3 4 and 5 have to run together
Will I be able to do this using interpipes with gstd deamon in jetson nano?
Yes you will be able to use gstd daemon and interpipes in that environment.
Regards,
Fabian
I’ve tried rtmpsink but when the rtmplink fails the device ram starts to accumulate until it overflow within seconds.
Is there a method to stop buffers going into ram when using interpipes?
