Gstreamer MJPG fail
Hi, I have a Jetson Nano C100 Developer Kit Module Okdo connected to a USB camera. I use Gstreamer to capture video.
The video formats available on that camera are:
But when I try to capture video in MJPG format, I always get an error like this:
I’ve tried different resolutions and fps, but the error always is the same.
If I use the UYVY format, it works, at any resolution.
Why does this error occur?
-Jetson has enough memory.
Would suggest try 1280x720p60 or 640x480p60. See if launching in lower resolutions still reports error
Yes, the error remains with any resolution…
Not sure if you have Jetson Nano developer kit for a try. C100 Developer Kit Module Okdo is from 3rdparty and probably the issue only occurs on the platform. Woudl suggest try default developer kit if you have it. Or may try USB camera from another vendor.
