Gstreamer MJPG
Hi, I have a Jetson Nano C100 Developer Kit Module Okdo connected to a USB camera. I use Gstreamer to capture video.
The video formats available on that camera are:
When I run the command to capture in MJPG format (at any resolution), I always get this error:
What’s the cause? The system has free memory.
Does it work if you capture UYVY? And you may try v4l2-ctl command to capture MJPG. See if it is specific to gstreamer v4l2src plugin.
Yes, it works with UYVY. But I’d like to use MJPEG; from using it with other cameras, it seems to have a better image.
Using v4l2-ctl doesn’t work either; I get the same error:
What does this error refer to? Would it be necessary to use a more powerful module?
I don’t understand, because there’s still free memory.
It looks to be an issue in UVC driver. You may follow this to rebuild kernel:
Failed to allocate memory for four usb cameras - #4 by fabian.solano
I already have that patch added, but the issue is when using these new cameras.
(VCI-AR0234-C-S83-IR)
Previously, I was using the (elp-usbfhd05mt-kl170ir), and with the patch, video was captured for all four cameras using mjpg.
A bit strange it errors out if you only launch single USB camera. You may add some prints in UVC driver to check further.
