GStreamer nvarguscamerasrc and v4l2src Elements Comparison on Flowchart
I’m currently trying to build optimized GStreamer pipelines on both Jetson TX2 and Jetson Nano (in order to use CSI cam directly). However, I get confused whenever I look at the flowchart below and can’t find any explanation that satisfies enough.
Can someone help me to understand what is going with this cart when using USB camera or CSI camera?
If I can get a basic explanation I would be very appreciated
One way to think of the architecture is that there are two paths for getting video data from the hardware to your application. One path is the typical linux video path, v4l2. The other path is Jetson specific that processes data through the ISP. USB cameras often support v4l2 although other software interfaces exist (i.e. USB 3 Vision). CSI cameras on Jetson allow you to pass the data either through v4l2 or through the ISP (argus) path. The ISP performs tasks such as debayer, color correction, and more. For CSI cameras it is very beneficial to utilize the ISP path.
At the application level you can process the data however you like. GStreamer is very popular. If your video data is passing through the ISP path you can use nvarguscamerasrc to easily get the data into a GStreamer application.
Thanks for the explanation. However, my actual expectation is which path (which arrows) the process takes when working with Argus or V4L2?
Argus flow is [V4L2 mediacontroller framework] → [camera core] → [libargus] → [libargus application].
USB camera is [V4L2 mediacontroller framework] → [V4L2 application].
If you run gstreamer, Argus is nvarguscamerasrc and USB camera is v4l2src.
Thanks for the explanation but I wonder how ISP is being utilized within the way you specified? Is it utilized through [camera core]->[tegra drivers]->[ISP]?
HI Doruk898,
The flow of frames from sensor to the user space when processed through ISP is as below:
[Sensor] → [VI-Bypass] → [Tegra Drivers] → [ISP] → [Tegra Drivers] → [Camera Core] → [libArgus] → [Application].
Note that the internal blocks mentioned in green are Nvidia proprietary and are enclosed within the libraries shared.
