Camera API Matrix
In page 61 in TEGRA LINUX DRIVER PACKAGE DEVELOPMENT GUIDE", there is a table named Camera API Matrix:
Uses Tegra ISP (CSI Interface) ------------- Camera API libargus , GStreamer (GST-NVCamera)
Does not use Tegra ISP (CSI Interface) ---- V4L2
USB (UVC) (USB Interface) -------------------V4L2
I don’t understand the above table, and would like to ask the following:
  1. What does it mean a “tegra ISP camera” ?
  2. I need to support DPI mipi cameras. Which column does it fit into ?
  3. If the camera is in the 2nd or 3rd row above, does it mean that I can’t use gstreamer with these cameras ?
Thank you,
ran
hello ranchu,
I would suggest you also refer to Camera Architecture Stack,
if the camera buffer going through [Camera Core], it means Tegra ISP is involved for post-processing.
you may contact with Jetson Preferred Partners for your DPI camera solutions.
it means nvcamerasrc plugin is not supported. you can still working with gstreamer with v4l2src plugin for your built-in ISP and USB interface cameras.
